I too have questions for Charles Papert - Page 2 at DVinfo.net
Open DV Discussion
Old October 23rd, 2002, 08:33 AM   #16
Retired DV Info Net Almunus
Charles,
Just wanted to say thanks for the response to my "controller" question.
I've gotta get my hands on one of those things! How many 7-11s would I have to rob to get one, I wonder?
John Locke
SursumFilms.com
John Locke is offline   Reply With Quote
Old October 23rd, 2002, 09:33 AM   #17
Josh:
Not sure about this second handgrip you describe. The pole will work best if gripped with one hand in the place I have described. If you hold on to it with another hand further down, you have eliminated much of the stabilizing power of the system. At that point all you have done is increase the mass of the camera which will make it somewhat more stable, but it will be prone to much more interference from your body mechanics by having both hands adding their own influence. If it is so heavy that one hand cannot support it, the best thing I can suggest is that the second hand support the first hand by grabbing it just below the wrist.
Charles Papert
www.charlespapert.com
Old October 23rd, 2002, 12:21 PM   #18
Slash Rules!
Really? Well, I can simply remove the handle. I got the design of a website about home built stabilizers. So the sway from side to side should just naturally eliminate itself?
Old October 23rd, 2002, 11:04 PM   #19
Yes. Ideally, the "sway" is actually the stablizing in effect. If the system is properly balanced and gripped in the manner described above, it shouldn't induce any negative "sway".
Charles Papert
Old October 24th, 2002, 10:46 AM   #20
<<<-- Originally posted by John Locke : Charles,
I've gotta get my hands on one of those things! How many 7-11s would I have to rob to get one, I wonder? -->>>
Do they have 7-11's in Japan???
Dylan Couper is offline   Reply
