Are broadcast television color systems even relevant for DVD authoring today? at DVinfo.net
Open DV Discussion
Old October 28th, 2009, 10:43 PM   #1
Hi, I have a pressing question. I have a DVD which I intend to market worldwide and was wondering if I need to encode it in different color systems like PAL and NTSC and SECAM for different regions worldwide. Isn't it true that almost all DVD players and televisions are multi-system these days, capable of automatically adjusting to the source colour system?
I'm looking to save some money by authoring it to one standard system (PAL) and going ahead with the worldwide distribution. Or would that lead to disastrous consequences?
Some advice would be most appreciated.
Windows 7 Ultimate 64-bit // i7 2600K // 16GB RAM // ASUS P8P67 Board // NVIDIA GTX 470
Sony Vegas Pro 13 // Adobe Premiere Pro CC 2014 // http://vimeo.com/alijafri
Ali Jafri is offline   Reply With Quote
Old October 29th, 2009, 03:58 AM   #2
Images: 32
Generally, PAL players are more likely to be able to also play NTSC, so encoding in NTSC is the safer bet. Vice versa, finding an NTSC player that can play PAL tends to be the exception to the rule.
But in the long run you are probably saving time & money by taking the time to encode in each format.
"Ultimately, the most extraordinary thing, in a frame, is a human being." - Martin Scorsese
Michael Wisniewski is offline   Reply With Quote
Old November 1st, 2009, 07:12 AM   #3
Ali, love your tag line btw!!! So true...
Geoffrey Cox is offline   Reply With Quote
Old November 1st, 2009, 10:47 AM   #4
Even when a player will play either PAL or NTSC, the TV to which it is attached is either one or the other. The player converts to the format that the TV supports. The resulting display in not as smooth as its native format. Converting frames per second (NTSC - 30, PAL - 25) and screen lines "hurts" the display quality. Since you describe your DVD as a commercial endeavor, it's appropriate to produce two versions.
Jim Snow is offline   Reply With Quote
Old November 1st, 2009, 05:42 PM   #5
You answered your own question when you said:
Do you want your DVD to play on ALL players or only on 'most' of them?
Ervin Farkas
www.AtlantaLegalVideo.com
Old November 14th, 2009, 02:04 PM   #6
No. While many (most?) PAL DVD players (in combination with agile TV sets) will convert NTSC to "PAL 60", even that is not a reliable thing to depend on across the planet.
And certainly, the number of customers in NTSC-land who can play native PAL DVDs is probably way less than 1% unless they play it on their computers, etc.
Recommended research:
PAL - Wikipedia, the free encyclopedia
Richard Crowley is offline   Reply With Quote
Old November 16th, 2009, 04:59 AM   #7
Why not save yourselves the headache and time by doing both.....
Eric Bakko is offline   Reply
