Grass Valley Model 110 was just dropped in my lap!!! at DVinfo.net
Open DV Discussion
Old January 12th, 2010, 01:44 PM   #1
Wow! A church member just loaned us a retired Grass Valley Model 110 (Standard Def.) from a TV station auction! It's the input/output rack-box and the switcher/t-bar console. He doesn't know how to use it, just got it on a lark.
We're kinda dumb-struck. Never worked with this level of gear before.
Aside from the obvious RCA-to-BNC adapters, what else will we need to work with this? We'd like to use 3 cameras and feed it to a computer for streaming.
We have Panasonic DVX-100s and Canon XL1s...any special needs for cable/signal/voltages/whatnot? to use with this rig?
Ted Bragg is offline   Reply With Quote
Old January 12th, 2010, 04:26 PM   #2
Ya got the cable that goes between the two? If not, ya got yrself a really nice door stop.
Otherwise, I'm 99% sure that all inputs must be synchronous and in time. That means that at least two of your sources need a genlock input. You can use the third source as the sync base. You'll need a DA to distribute sync to the cameras. And you'll need a way to get the sources in time.
If the cameras do not have genlock in, you'll need a frame synchronizer for each input.
Its not really a tool for prosumer use.
Andy Tejral
Railroad Videographer
Andy Tejral is offline   Reply With Quote
Old January 12th, 2010, 05:45 PM   #3
A nice pro mixer but it may be too much for your own use, this is where the self syncing panasonic mixers are better suited to non pro set-ups.
Old January 12th, 2010, 05:58 PM   #4
Not to mention it may be component as the one I used today for a 3 camera corporate job is.
Mark Bolding is offline   Reply With Quote
Old January 12th, 2010, 06:02 PM   #5
See if someone can loan you a Tricaster; that would be sweet!
Old January 14th, 2010, 01:31 PM   #6
It came with all the wires for the unit. No word on what kind of TBC or Frame Sync to get? Our recording device is a h.264 PVR with composite/rca inputs.
Which end do I stick TBC/Frame Syncs onto? Incoming or outgoing?
