Rack Focus at DVinfo.net
Open DV Discussion
Old March 23rd, 2010, 04:18 AM   #1
Rack Focus
rack focus is a nice effect but when I do it the image kind of shifts. Increases and decreases a bit like I'm using the zoom, which i'm not. I don't recall seeing this when I've seen similar shots on tv. am i doing something wrong? I'm using a Sony DSR 500 if that helps.
Leslie Knox is offline   Reply With Quote
Old March 23rd, 2010, 06:19 AM   #2
When you focus, you move a lens in a lens assembly. Depending on the build of the lens assembly, zooming may or may not also happen at the same time.
Ervin Farkas
www.AtlantaLegalVideo.com
Old March 23rd, 2010, 06:49 AM   #3
It's called lens breathing. Most lenses suffer from this to some extent. Really expensive lenses have measures to prevent this from happening.
Edward Carlson is offline   Reply With Quote
Old March 23rd, 2010, 08:31 AM   #4
Most 2/3" zooms breath when adjusting focus. The Canon wide angle zooms don't breath to a noticeable extent. What can work with some shots is to use the macro for the rack focus, setting the focus ring for the distant object and pull using the macro - it's very much an eye focus job.
Old March 24th, 2010, 02:50 PM   #5
Double check the back-focus adjustment on the lens.
David W. Jones
www.joneshdfilms.com
David W. Jones is offline   Reply
