Are all mpeg2 files created equal? at DVinfo.net
Open DV Discussion
Old July 28th, 2010, 11:02 PM   #1
I know that different codecs have different quality levels when burning a DVD. But what about when simply creating an mpeg2 file. Can one nle system create a higher quality mpeg 2 than another?
Kevin Lewis is offline   Reply With Quote
Old July 28th, 2010, 11:19 PM   #2
You better believe it!
Old July 29th, 2010, 12:47 PM   #3
I know MPEGS can consist of various make ups, but I typcally export mpeg2 1080i files that ultimatly make there way to dvd. If I use another NLE to create a file with those same specs, is it still possible for one 1080i to have a higher quality then another 1080i. I thought that because were talking about a digital file, that the mpegs would be the exact same quality. I typically edit in Pinnicale Studio 12. I like the simplicity of it but want the option to export to another system where I can make my dvd's more compatible with the various players that are out there.It seems that the dvds that I create from this program dont always work well on various players.
Old July 29th, 2010, 12:53 PM   #4
Not only is it possible, it's essentially guaranteed.
We are talking about a digital file. But not a lossless one. Each Mpeg2 encoder is looking at the source material and making hundreds of guesses per frame of video about how to encode that information. Some encoders guess better than others. Some take their time and work for best quality. Others try to appease the crowd who wants it fast. Some walk the line between the two extremes. All Mpeg2 is not created equally. How much artifacting do you see in Hollywood DVDs? How much do you see in your home burns?
Old August 2nd, 2010, 11:09 AM   #5
As far as I know, good Hollywood DVDs are kind of "manually encoded". That is if the encoder's choice of bitrate and whatnot for a certain scene is bad, then this scene will be encoded with better settings until it fits.
And of course there is always good software and bad software. Some encoders just do a much better job than others.
Heiko Saele is offline   Reply
