How to prevent/clean dirt on lens at DVinfo.net
Open DV Discussion
Old October 20th, 2010, 03:46 PM   #1
Ok, I'd like ideas on how to do this. I shoot a lot of outdoor stuff, usually with the lens at wide angle (currently a Canon HXA1s, but this really applies to any small chip camera). I constantly fight with tiny specks of dirt on the lens, usually right in the middle of the sky or clouds, so that it's extremely obvious. The dust is generally too small to see, and I really do try to keep my lens covered when not in use, and clean, but it very often shows up.
Anyone have any good ideas on how to keep the lens clean to begin with, best methods of cleaning, etc.? I usually open the lens up to minimize depth of field on wide angle shots as well, but maybe there's some obvious way to avoid this that i haven't thought of.
Thanks.
David Dice is offline   Reply With Quote
Old October 20th, 2010, 05:00 PM   #2
A decent UV/skylight filter is your best option for keepnig the lens itself clean. While you're still going to get dust on the filter, you can feel much safer about wiping it and cleaning it regularly, even while you are in the field, knowing that if you scratch it you're not going to need to replace the whole lens for $2000! Also, because the filter is less recessed than the actual lens it makes it easier to see properly and to and inspect it for dirt.
I shoot alot of surfing so salt mist is a constant problem on the beach. I just use a clear skylight filter all the time and clean it regularly with a lens tissue & lens cleaner solution.
John Wiley is offline   Reply With Quote
Old October 23rd, 2010, 06:43 PM   #3
Well, but a UV filter (or any filter) is also another plane of glass that accumulates dust and stuff - and usually you see that a lot more in your footage than if the dust is directly on your lens...
I never managed to get a good shot against the light with a filter on the lens - at least not as good as without the respective filter.
I always try to keep my lenses as clean as possible with a lens brush and cleaning paper. It is better than any kind of cloth because you're always using a fresh piece and there is no fuzz/lint from it.
Heiko Saele is offline   Reply With Quote
Old October 25th, 2010, 02:17 AM   #4
With exposure to salt air and spray, I use microfiber lens cleaning cloths.
I have several on hand and launder them when they get dirty. There's also a cleaning spray that I apply to the cleaning cloths to help clear anything that might smudge the lens.
This doesn't scratch the element nor does it damage the coating.
Dean Sensui
Old October 26th, 2010, 08:31 AM   #5
thanks for useful information...
Bredly Root is offline   Reply With Quote
Old October 26th, 2010, 11:14 AM   #6
You should remove as must dust and debris from the lens with air first. Some of the dust is abrasive and if you rub it, no matter how soft the cloth is, it can make small scratches on the lens. It doesn't take much of a scratch to be visible when the light is shining into the lens.
Jim Snow is offline   Reply
