Peaking and older lens at DVinfo.net
Open DV Discussion
Old November 17th, 2011, 07:49 AM   #1
Hi all,
In the process of getting to know my first real "pro" camera. Been playing will all the settings and such. I've made an observation, and wanted to ask if my conclusions are correct. I'm currently using very inexpensive canon fd lenses, until I have the funds for, nicer higher end lens. When using the peaking function (has 3 settings, high, medium, and low. I'm using set on low), I've noticed situations when I have (or feel I have) good focus (on what it is I'm trying to focus on), but there is no peaking indication at all, and other times when there is. With out having a newer, better quality lens to compare it to yet, I'm concluding that this is showing my older lens to be less, sharp at times. I'm wondering if that is correct? This is my first interchangeable lens camera, and am learning a lot, about many different things. I'm a person who isn't so great at being taught things, but rather I need to dig in, and figure things out on my own.
Thanks for your comments,
Jeff
Jeff Troiano is offline   Reply With Quote
Old November 17th, 2011, 04:15 PM   #2
Re: Peaking and older lens
Try medium or strong peaking. Also, according to this article, the FS100 may see a 4x and 8x Expanded Focus in a firmware update. That will also help in getting critical focus.
http://www.photographybay.com/2011/1...ocus-settings/
Some testing may also help. Shoot something that has some depth and make a record of whether you have peaking indicated then look at the footage and see if was truly in focus an the peaking not indicating or whatever.
Remember, peaking is based on contrast so not everything that's in focus may get peaking indicators.
Old November 18th, 2011, 01:55 AM   #3
Just about any decent lens for 35 mm stills build in the last 50 years is more then adequately sharp for HD video, your Canon FD are (more then) up to the job.
Peaking is driven by high contrasts and where this is not present in the subject, there'll be no peaking.
Frans Meijer is offline   Reply With Quote
Old November 24th, 2011, 05:41 AM   #4
@Jeff, can you update this thread for others who may run into the same thing? Is there a peaking setting that you found useful?
Old November 24th, 2011, 08:08 AM   #5
I had been using my camera's peaking setting, on the low setting. It was suggested to me, that I should use the medium setting. I'm getting much better results with this. I've also started using the expanded focus function more. And very soon, there will be a firm ware update, that will allow me to have 4x and 8x expanded focus.
But is seems, every where I've asked, it wasn't necessarily my older lens were soft, that only there wasn't enough contrast at certain times, for the peaking function to work.
Old November 25th, 2011, 04:15 AM   #6
I am tempted towards a contrary-opinion regarding older 35mm stills lenses. I know Nikons may not be Canons however sharpness registered by numbers on a SI2K camera 2/3" sensor with the best Nikons I had was just over half of the Super16mm lenses. The 35mm stills lenses were also more sensitive to being out of "sweet spot" aperture settings.
Peaking is a convenient tool with practice for quick or agile work however I still favour using a Siemens chart when I can to set my focus marks in other circumstances but I am a short-sighted cameraman with deteriorating close vision. If the original poster is using a camera with a 35mm sized sensor, then my opinion should be ignored.
Old November 25th, 2011, 06:03 AM   #7
It wasn't stated but the camera the OP is using is the Sony FS-100 which is a super 35 sensor.
Old November 25th, 2011, 08:29 PM   #8
In that event, my comments should slide their way quietly out of the dustpan into the dustbin of history as they are now irrelevent.
Old December 5th, 2011, 03:43 AM   #9
Try stepping the lens down to f/2 or f/2.8 and see if it shows up. Also try boosting EV compensation a bit (like +0.7). It should show up on sharper edges.
Charlton Chars is offline   Reply
