Q: Intranet video camera streaming at DVinfo.net
Open DV Discussion
Old July 31st, 2012, 01:44 PM   #1
There's an upcoming event at a non-profit location, that they would like to stream live to two separate locations on the same campus. Here's what we're working with:
- HVX200 w/ firewire in to MacBook Pro
- Windows computers projecting into viewing locations
- campus-wide wifi (unknown speed)
So I need (probably) a cross-platform streaming solution. I THINK VLC only streams video files, not incoming firewire streams (fiddling with it currently, haven't found what might make the firewire bit happen)
Cheap is paramount here, don't need super-high-quality by any means... just sending a simple SD stream over intranet.
What are my options?
www.mcbob.tv
Kevin McRoberts is offline   Reply With Quote
Old July 31st, 2012, 03:03 PM   #2
Re: Q: Intranet video camera streaming
Read this. If it makes any sense you stand a chance. ;)
DIY BROADCAST : How to build your own TV Channel with Open-Source & other goodies - Video & Dev Breakthroughs
http://www.LandYachtMedia.com
Old July 31st, 2012, 03:36 PM   #3
If I understand you, you'll be live into a Mac and then out to your server? Quicktime Broadcaster (freeware from Apple) might do what you want; if you are streaming into Windows, try Microsoft Expression Encoder 4 (also freeware, from Microsoft).
Old July 31st, 2012, 05:33 PM   #4
There's been a slight change that makes this a ton easier... only streaming to one location.
Unless it fails hopelessly on the projector end, we're just going to do Facetime from the Macbook to an iPhone with a RCA breakout cable into a switcher to the projector.
I'll check into QT Broadcaster and MEE4 as well, just in case. Thanks
www.mcbob.tv
