EX1....is it still worth its weight? at DVinfo.net
Open DV Discussion
Old August 11th, 2012, 09:02 AM   #1
Im considering a used cam purchase and for the sake of argument I'll use it for everything....I was going to buy the Canon XF105 but looking on ebay I see the ex1 at the same price. Im particular to canon as Ive had the gl1, xl1, xl1s and xl2. But from what ive read the ex1 is the optimum cam... I guess what im looking for is the straw that will tip me to either of the two... then theres also the jvc gyhm700 series that I like only because of its native quicktime to fcp workflow... thanks for any response guys!
"Catering to all of your needs, from A to V."
Sam Rosado is offline   Reply With Quote
Old August 11th, 2012, 10:38 AM   #2
Re: EX1....is it still worth its weight?
If the EX1 is still in pristine condition, get it! The XF105 is a single sensor 1/3'' sensor camera whereas the EX1 is a full 3-chip 1920x1080 1/2'' sensor camera. This means the EX1 is theoretically better in low light.
XDCAM Browser converts XDCAM EX to MOV files pretty easily, so you shouldn't have too big of a workflow problem to solve.
Do double check with the seller to be sure you're getting what you asked for, but definitely take a EX1 over a XF105 any day.
Old August 11th, 2012, 01:33 PM   #3
There aren't many used XF100's for sale because it is a new camera. On the other hand the EX1 has been replaced by the EX1R which was just replaced by PMW200. The cameras are different designs for different purposes: The XF100's main feature is being small, the EX1's main feature is having 1/2" sensors. Both are best in their class.
You say you will use the camera for everything, but that is not very specific. Are you carrying the camera on a mountain climbing expedition or placing it on a tripod in a church?
Eric Olson is offline   Reply With Quote
Old August 11th, 2012, 03:53 PM   #4
Thanks Jack! im def leaning that way!
Old August 11th, 2012, 03:56 PM   #5
ummmmm....how is "everything" not specific??? i might want to take it with me to juarez mexico when I go unicorn smuggling or maybe into the sewars of NY when im big rat hunting!!! smh.....
btw.....there are PLENTY of used xf100's for sale. but thanks for your response anyway!
Old August 11th, 2012, 10:02 PM   #6
The XF100 would be the superior camera when unicorn smuggling, but the EX1 would be better when big rat hunting. Depending on how much water is in the sewers you might also consider the NX70.
Old August 11th, 2012, 10:43 PM   #7
EX1 is much better camera anyday sir.
Lee Mullen is offline   Reply With Quote
Old August 17th, 2012, 03:45 AM   #8
The EX1 does a great job.
If you can get an EX1r then even better, in my opinion, because of the pre-record buffer.
Dean Sensui
Dean Sensui is offline   Reply
