DVD Editing Information at DVinfo.net
Open DV Discussion
Old August 15th, 2012, 07:56 AM   #1
Dumb question(s) from a newby. Can you suggest a good BASIC book on video editing. I am trying (just starting) to create some DVD's and am unable to use the video editing software that I have (Corel and Sony). I am unable to open a VOB file with either program. What format should I change the VOB file into in order to edit it. Nope, I am not a blond. Jim Moffitt
Jim Moffitt is offline   Reply With Quote
Old August 15th, 2012, 11:58 AM   #2
Re: DVD Editing Information
Are you shooting with a video camera that records onto mini DVDs?
Eric Olson is offline   Reply With Quote
Old August 15th, 2012, 06:38 PM   #3
Yes, records on mini DVD's (3 inch ?). Camera is a Canon DC320 and I have recorded on both DVD-RW and DVD-R. Same results on both types of media. Can't read VOB files. with either Sony or Corel. Thanks for any advice. Jim Moffitt
Old August 15th, 2012, 08:35 PM   #4
Try changing the file extension .vob to .mpeg.
If that doesn't work, us MPEG Streamclip - open the DVD, then go to File > Save as MPEG.
Ervin Farkas
www.AtlantaLegalVideo.com
Old August 16th, 2012, 03:13 AM   #5
With Sony Vegas it should just work. What version are you running?
Old August 16th, 2012, 07:22 AM   #6
I have Vegas Movie Studio 9.0, but to say that I am using it would be a real stretch :(. Jim
Old August 16th, 2012, 07:26 AM   #7
In Sony Vegas connect your camera to your computer or copy the VOB files to a directory. Go to File>Import>DVD Camcorder Disc. That will pull the files into your timeline and rewrap the footage so that Vegas will work easily with it.
Garrett Low
www.GLowMediaProductions.com
Old August 16th, 2012, 06:39 PM   #8
Thanks Garret: OK, will try that. Thanks for the info. I will also try changing the file extension per Ervins advice (didn't know file extensions could be so easily changed).
Sincerely, Jim
