Viewfinder pin connections ??? at DVinfo.net
Open DV Discussion
Old December 1st, 2002, 04:13 PM   #1
Does anyone here happen to know the pin connections on a 80s Sony Video 8 cam B/W viewfinder?
The plug/socket is a small (about 10mm dia) with a large center pin and eight smaller pins arranged in a circle about the center pin giving 9 pins total.
The viewfinder itself is a 1 inch tube type drawing a 5v supply and is high quality.
John Jay is offline   Reply With Quote
Old December 2nd, 2002, 02:01 AM   #2
Moderator
Jay,,, you dawg you,,, I bet I know what you are thinking of doing with that viewfinder!
Keep us posted if you find anything useful, ok?
Looking forward,
- don
DONALD BERUBE - noisybrain. Productions, LLC
Director Of Photography/ Producer/ Consultant
http://noisybrain.com/donbio.html
CREATE and NETWORK with http://www.bosfcpug.org
and also http://fcpugnetwork.org
Don Berube is offline   Reply With Quote
Old December 2nd, 2002, 10:19 AM   #3
<<<-- Originally posted by Don Berube : Jay,,, you dawg you,,, I bet I know what you are thinking of doing with that viewfinder!
Looking forward,
- don -->>>
Hey Don - you've blown my cover :)
seriously though I was clearing out my garage when I came across old toby - SONY V7AF c1986 - a 'big box' machine which paid for itself 50 times over during 1986 -1988.
I thought I would bang it on ebay but when I checked to see what they fetched (buttons) I reconsidered and decided to break it up - use the cam section as a surveillance on the back porch - use the nice ecm mic for something and yes I wonder what a B/W 1 inch CRT tube viewfinder would be like with the VX2K or even a DVX100?
The old T-bar style viewfinder has got a superb picture has dioptre adjustment and is ideal for critical focussing and comes with its own sliding hot shoe plate like it is made for the job!.
WOW i thought I bet this alone is worth a few hundred bucks.
So I need to know where the power pins and the video pins are located so i can make up new cables and then I am set. Even if used on a 1-2 metre lead this would be ideal for monitoring a second cam
an old service manual would do the trick so if anyone out there can help me find the info I will write a report here on whether it works. BTW the model number on the viewfinder is VF-236
(FYI when opened up there are preset pots on the PCB for brightness and contrast - cute heh?)
watch out for a second generation market in these old viewfinders !!!
Old December 3rd, 2002, 04:43 PM   #4
Moderator
Jay,
Contacting a Sony repair facility is you rbest bet. Ask them how to get that info.
Keep us posted,
- don
Old December 3rd, 2002, 09:36 PM   #5
Warden
If Sony won't (or can't, it’s pretty old) give you the specs, find a repair shop with the schematics or micro fiche. The schematics will give you all the voltages for the pins.
Jeff
Jeff Donald is offline   Reply
