Cable wrap at DVinfo.net
Open DV Discussion
Old November 25th, 2018, 07:02 AM   #1
Cable wrap
I am making a custom loom as in 1 cat5(for control), 1 coax (for video) and power (this maybe low voltage as in 12 or mains) this is for a video camera that is ptz.
I would like to know what others have used to wrap cables and how did you find rolling it up after an event. Speaking of events this could be crossing a path where people could be waking so it could get stood on as well.
I was looking at spiral wrap and braided sleeving. The spiral wrap is not the cheep stuff that would use behind the tv or pc.
Tony McGuire is offline   Reply With Quote
Old November 26th, 2018, 11:16 AM   #2
Re: Cable wrap
Techflex is my go-to. Adhesive heat shrink at the ends, and make sure to cut the Techflex with a hot-knife.
Edward Carlson is offline   Reply With Quote
Old November 27th, 2018, 07:17 AM   #3
Re: Cable wrap
Hi Edward,
I was thinking braid wrap would be better and when I done a search for Techflex I have found a few people using it for what I was thing of doing. I was going to use heat shrink on the end but did not think of the adhesive heat shrink one. I think it will be the way I will go as in braided wrap. I will try and get Techflex here in Ireland.
Old November 27th, 2018, 07:42 AM   #4
Re: Cable wrap
I just made camera cables with 3 Cat5 cables for my Vaddio PTZ cameras. Look for the scissor cut TechFlex. Doesn't need a hot knife and wraps very easy.
David Stoneburner is offline   Reply
