Firewire drives... good/bad for DV? at DVinfo.net
Open DV Discussion
Old February 7th, 2003, 11:26 AM   #1
Rich Conley
Posts: n/a
Has anyone had any experience with Maxtor 120GIG firewire external drives with 911 princeton chipset casings for an Express DV setup?
or any fierewre drives used for digital video.
How do they respond? Do they work well if a hub is used to connect multiple drives?
Old February 7th, 2003, 01:06 PM   #2
i use a WD 200 firewire drive as my main dv drive at the moment. its great. very fast, stable, etc.
- brian
This is the way the world ends.
Brian Pink is offline   Reply With Quote
Old February 7th, 2003, 01:28 PM   #3
Warden
Do you mean 911 Oxford chips?
Jeff Donald
Carpe Diem
Old February 7th, 2003, 02:10 PM   #4
Air China Pilot
I have two 120 gig drives daisy chained to my workstation. One is an IBM Deskstar and the other a Maxtor.
I do not capture through the Firewire but I do use them as work drives during rendering.
And of course I use them for storage.
Visit http://www.KeithLoh.com | stuff about living in Vancouver | My Flickr photo gallery
Keith Loh is offline   Reply With Quote
Old February 7th, 2003, 02:38 PM   #5
Moderator
Make sure they are 7200rpm drives, I have always found that you get minimum problems with this fater rpm speed.
Not sure how maxtor would hold up to daily editing and capturing, I have never used Maxtor, not sure why though... so I oculdn't really comment on them.
We do use two of the Lacie D2 200GB drives, and also two of the Lacie D2 120GB drives. The 200GB models have the 8mb buffer which really does add performance value over the older 2mb designs. We have no problem with these drives at all, very quiet and heavy-duty performing drives.
http://www.lacie.com/products/product.htm?id=10022
- don
DONALD BERUBE - noisybrain. Productions, LLC
Director Of Photography/ Producer/ Consultant
http://noisybrain.com/donbio.html
CREATE and NETWORK with http://www.bosfcpug.org
and also http://fcpugnetwork.org
Don Berube is offline   Reply With Quote
Old February 7th, 2003, 09:11 PM   #6
Contributor
We have 5 of them and they work fine. One is the Maxtor 120 gig; the others are Lacie. At first we had 4 daisychained (using Avid XDV on dual gig G4's) on one system, and there were some difficulties. It seems that, even though there are two firewire ports, the G4 doesn't like it if you have a DVCAM deck such as the DSR1800 plugged into one and the drives into another. Simple solution was a pci card. It has 3 ports, so 3 of the drives are direct and the fourth is daisychained. That system is now working fine. The second system has 3 internal 120 gig media drives and so far one Maxtor 120 gig that goes back and forth between the two systems, so the system with the external firewire drives sometimes has 5 attached. No problems at all, once we figured out that thing about the deck. I dunno why the heck they put 2 ports there if you can't use them both, but that's the way it is. The reason our second system has all the internal drives is because we hadn't yet figured out the problem of the first system when we bought the second, so the Avid dealer put in the internal drives. But now both systems work perfectly.
The damn things feel so small and lightweight and flimsy compared to the old Avid SCSSI drives we used with Media Composers for so many years, and they're so cheap, that I still expect them to self destruct or something, but they seem to work flawlessly.
On the system with the internal drives, 4 total if you count the system drive...I sort of expected heat problems and planned to stick a fan beside the computer. But I was pleasantly surprised to find that there's no excess heat at all. The new G4's have pretty good fans, I guess. Maybe that's why they're noisy. The computers and drives live in cabinets behind glass doors, but the backside of the cabinets is open so heat can escape.
Anyway, I think firewire drives are wonderous things. I can put several hours of footage on a single drive, do the offline edit...take the drive to the second suite for graphics and music, then bring it back for other effects, export, etc., and life is good with no need to spend gazillions of bucks for Unity.
Old February 7th, 2003, 11:23 PM   #7
I use a Maxtor 7200 RPM Fire wire drive with 2 editing systems (soon to only be one), one is a Adobe Premier 6.0 windows 2000 system, and the other is a Final Cut Pro setup. The Drive works equally well on either platform. I just re-format the drive wen I need to switch between Mac, and PC. I think it was the Avid web site that recommended the Maxtor 7200-RPM drives for Express DV 3.5 so they must work well for the Avid DV’s.
Alex
Alex Ratson is offline   Reply With Quote
Old February 8th, 2003, 09:42 AM   #8
Rich Conley
Posts: n/a
Thanks everyone...
Bill that's pretty much the same system I'm configuring. I have 3 300gig drives internally
(WD) and a DV dec (DSR11) connected to one firewire port. That's too bad about the other port not working. I'll give it a try and see, but i'll make sure to have a card ready just in case. I'm curious, what type of problems occurred without the pci card? The place i'm buying the drives from told me that the casings only have one firewire port, is that ok for dasiy-chaining? How does you's work?
One more thing, does it make a difference it the drives are bus powered or external powered?
Thanks again.
