Focal Length Comparison at DVinfo.net
Open DV Discussion
Old June 30th, 2006, 12:07 AM   #1
Found this from somewhere in the net...
(1/3).....(1/2).....(2/3)......S16mm.....35mm.....Angle of View
2.2.........3.1........4...........5.7...........12...........95°
2.5.........3.5.......4.5..........6.............13...........89°
2.8.........3.9........5............7.............14...........82°
3...........4.25......5.5..........8.............16...........77°
4.3..........6........7.8..........11............22...........59°
6.8.........9.5.....12.3.........17.5..........35...........41°
9.7........13.6.....17.6.........25............50..........28°
16.5.......23........30...........40............85..........18°
19.3.......27........35...........50...........100.........15°
39.........54.5......70..........100..........200..........7°
45.........63.5......82..........120..........240..........6°
86.........121......156.........200..........400.........3.25°
172........242.....312.........400..........800.........1.75°
maybe usefull for some of us...
Hornady Setiawan is offline   Reply With Quote
Old June 30th, 2006, 12:21 PM   #2
Contributor
Excellent--thanks for that.
Old June 30th, 2006, 12:54 PM   #3
Images: 1
Yes I meant to add a thank you when I moved his thread from the XDCAM forum. I felt it was good for all camera users to see.
-gb-
Old June 30th, 2006, 02:27 PM   #4
That is a cool chart - thanks for posting it. However I think the 35mm number is based on 35mm movie cameras. That's fine, but the numbers published in most prosumer camcorder specs compare the lenses to 35mm still camera equivalents, so caveat emptor. For exaple, the telephoto end of the zoom on my Z1 is 54mm which Sony says is equivalent to a 390mm lens for on a 35mm SLR. However that chart shows an 86mm lens with 1/3" chips being equivalent to a 400mm lens for a 35mm camera.
Old July 1st, 2006, 09:51 PM   #5
yep, those numbers are 35mm film lens, not 35mm photography lens...
Old July 2nd, 2006, 12:36 PM   #6
That's a very useful chart, just too bad it doesn't include 1/4"
Duane
Duane Burleson is offline   Reply
