#16 | |
"MPC believed the best results occurred with footage shot in the 4x3 aspect ratio but matted for 16x9 by the PAL XL1 (625 lines of resolution, 900,000 effective pixels over three 1/3" CCDs)" Sure. Go to System Preferences > International and click the Input Menu button. Now click the Keyboard Viewer checkbox and the Show input menu checkbox. Now you can click on the little flag at the top righthand corner of the menu bar and show the keyboard viewer. If your keyboard doesn't have a bracket key then it will probably be available by holding down the option key, or maybe option+shift. When you do this you will see the hidden characters on the little keyboard viewer. |
#17 |
He did shoot a lot of movies 1.37 but they were released as 1.66. It doesn't matter what the negative was, it matters what the millions of viewers saw when they went to the theater. The final product. Which was widescreen.
Damnit Jim, I'm a film maker not a sysytems tech. |
#18 | |
http://www.amazon.co.uk/Canon-DM-XL1...ata/B00005QF76 If they shot with an anamorphic lens then they would get the full 300k, if it was matted it would be even lower. They did a very good job with that film. Pushing a prosumer cam to its limits. I read that it was quite soft when projected on the big screen, but it looked very nice on DVD.
#19 | |
#20 |
The distance your film will travel is directly related to one issue: does it successfully connect with an audience? Period. You can argue over aspect ratios and lines of resolution until you’re blue in the face. The audience generally doesn’t care. They’ll accept whatever format you give them as long as your sound is good, your camera's in focus and the story is captivating. A boring story at 4:3 isn’t any more interesting 16:9 or Hi-Def. Don’t get distracted by techno-babble. After 25 years of scriptwriting, I’ve learned to keep one thought in mind at the front of all others: It’s the story, stupid. I keep that message on a sticky above my monitor with each script I write.
Brian Keith Moody, Writer / Director Canon XH-A1 - PowerMac G5 - Final Cut Pro - Shake |
#21 |
Yes, totally rediculous. 16x9 is ruining television and the sky is falling as well. I found it funny to see no author on this peice.
#22 |
American Society of Cinematographers
Cinema stopped being 4x3 some fifty years ago, so it's hardly a disaster that TV is just now catching up.
The "golden rectangle" in art is close to the 1.66 : 1 ratio. Kubrick did not "compose" his movies for 4x3. They were composed for theatrical projection masking to widescreen (1.66 or 1.85). People who have worked for Kubrick have told me this directly. Cameras were marked for widescreen framing, editing equipment too, etc. There is a story in Ciment's book on Kubrick by the publicity exec at Warner Bros. about having to check every cinema in the U.S. to make sure that they had a 1.66 mask to show "Barry Lyndon" -- and in fact, both "Barry Lyndon" and "Clockwork Orange" were shot with hard mattes in the camera, which is why the DVD and former laserdisc versions (that one supervised by Kubrick) were in fact letterboxed mildly. But by the time he did "The Shining" he was shooting 1.37 Academy, protecting the whole negative, but composing for theatrical. But he preferred that these last three movies be shown in 4x3 on TV. Why? Partly because he didn't like electronic matting (he didn't mind camera mattes being visible though) and because he liked the old 1.37 Academy frame and saw 4x3 TV as a way of getting that effect. But that doesn't mean he primarily composed the movies for 4x3 TV. True 4x3 composition would use the whole height of the frame for balancing objects, but his last three movies show obvious excess headroom in all of his medium shots to allow for widescreen projection matting. Of course, we can quibble over the definition of "composing" all day... but to me, if you factor in the widescreen cut-off, you are defacto composing for it. Working within a frame is the definition of composition.
David Mullen, ASC Los Angeles |
