QuickTime codec H264 quality question at DVinfo.net
Open DV Discussion
Old April 30th, 2007, 08:42 AM   #1
Awhile back I asked around and was told h264 was the best quality for file size out there, and alot of people here use it to post videos. But when I use it it looks very flushed/washed out. Here is a screen shot with mpeg-4 vs. h264 so you can see what I mean. While the h264 file is about %40 smaller, the image to me looks horrible in comparison. They were both on best/highest quality going out of premiere (m2t) through debug frameserver and compressed with tmpgenc pro. Why does my h264 look so horrid? :(
http://www.kiukle.com/temp/qt.jpg
Cinematography Site
Nathan Quattrini is offline   Reply With Quote
Old May 3rd, 2007, 07:42 AM   #2
I have to say I'm a tad disappointed no-one has responded. I, as well, have had this same problem. I tried doing some tests using h264 after hearing how good it is, and also got the same washed out result.
Matthew Craggs is offline   Reply With Quote
Old May 3rd, 2007, 08:03 AM   #3
Are you using Premiere's encoder or Quicktime's?
I'm a Final Cut Pro user and the H.264-encoded videos are clearly superior to MP4, and even better if I twiddle with some of the esoteric settings in Apple's Compressor.
me@facebook: http://facebook.com/stevemallerphotography
Steve Maller is offline   Reply With Quote
Old May 3rd, 2007, 09:56 AM   #4
Agreed. I use QuickTime as well (from Final Cut Pro) through Compressor and the quality is outstanding. The only thing I've heard of that can rival it is On2 Technologies Flix Series (eg Flix Exporter). Check here:
http://on2.com/
Adam Tirapelle is offline   Reply With Quote
Old May 3rd, 2007, 10:45 AM   #5
I have same problem, when exporting it from After Effects. Result looks washed out and much brighter than original
Andzei Matsukevits is offline   Reply With Quote
Old May 3rd, 2007, 11:13 AM   #6
Ive generally found quicktime player itself actually contributes to the problem, playing the same clip in another player returns results more in line with the original clip with both at their default settings
eg dual screen grab of the same clip paused in two different players
http://www.webhosted4u.com/vlc_v_qt.jpg
I've overlayed a section from the QT player screen grab on top of the VLC players grab to make them easier to compare
Steven Cowie is offline   Reply With Quote
Old May 3rd, 2007, 12:03 PM   #7
It's a color space problem. I think it is QuickTime's fault. See this
Emre Safak is offline   Reply
