AC160a 1080/60p?? at DVinfo.net
Panasonic AVCCAM Camcorders
Old April 21st, 2013, 12:01 PM   #1
AC160a 1080/60p??
Hello all -
I thought this cam was able to shoot at 1080/60p.
Looking at the Panny website for this cam, I don't see a 1080/60p setting for this cam.
Can anybody let me know if I am reading the specs correctly or not?
Andrew Clark is offline   Reply With Quote
Old April 21st, 2013, 01:55 PM   #2
Re: AC160a 1080/60p??
The 160 has it, the 130 does not. There is a firmware update for the original AC160 that I applied to enable 1080p60 on the camera. I would assume the "A" version has it enabled already, but if not, a simple firmware update will do the trick.
Nate Haustein PXW-FX9 / FCPX
www.flightcreativemedia.com
Nate Haustein is offline   Reply With Quote
Old April 24th, 2013, 11:38 PM   #3
That is correct. The 160 needs a firmware update free from Panasonic to get the ability to use 1080/60p. The 160a has it already installed.
Steve Wolla is offline   Reply With Quote
Old May 12th, 2013, 06:36 PM   #4
Thanks for the replies / info.!!
By the way, how do you all like this cam?
