NV 100K Software ? at DVinfo.net
Old August 11th, 2003, 01:26 AM   #1
NV 100K Software ?
What softaware are people using to down load their NV100 footage ?
Can I use the English version Software from the PAL NV 70.....If I could get my hands on it....Just a questions because I dont even have a worthy PC Yet!
but getting ready for when I do.......
Cheers,
Lincoln
Lincoln Norris is offline   Reply With Quote
Old August 11th, 2003, 02:55 AM   #2
Outer Circle
I'm sure that the N.A. GS70 video editing software will work with the GS100 cam, and probably other pana cams as well. In fact, if you buy any major editing software, in English or Japanese, it should work. However (the kicker), in the past some low-end editing software either worked with PAL or NTSC (only), depending on where you bought the software package. :)
Frank Granovski is offline   Reply
