What UV? at DVinfo.net
Old December 15th, 2003, 08:12 PM   #1
Outer Circle
What UV?
What UV filter do you use for your Panasonic? What other filters do you use?
I've been mainly using a Cokin UV, Cokin circular polarizer and Cokin Sunsoft.
Old December 15th, 2003, 10:36 PM   #2
I use a Hoya UV filter (multi-coated) for my MX5000.
Young Lee is offline   Reply With Quote
Old December 15th, 2003, 10:41 PM   #3
Outer Circle
I wanted to buy a Hoya, but no one carries the thin, multi-coated model locally. :-(
Old December 16th, 2003, 02:40 AM   #4
I have stepped my MX350 permanently from 43mm to 55mm. I am using the Super HMC UV(0) from Hoya.
Say Frank, if I can get the Pro HMC here, would you want me to mail it to you?
Yow Cheong Hoe is offline   Reply With Quote
Old December 16th, 2003, 02:51 AM   #5
Outer Circle
How much is it? Let me know via e-mail about price. Thanks! Actually, I need one for one of my lenses, in the 52mm thread size.
