MX-500 (953) oversaturation at DVinfo.net
Old January 2nd, 2004, 02:58 AM   #1
i just thought that i might put in a post to see if anyone else has suffered this problem before. when i am filming something that is deep in color like purple of orange and red i have problems with oversaturated colors. apart from this the colors on this camera are dead accurate and beautiful. the camera seems to do it more when the sun is bright possibly from under exposure but even when i open it up i can get the right color but the highlights and shadows are not correct and the background becomes over exposed. if anyone has some help on this matter i would appreciate ur advice. if you want info on this camera feel free to ask also. just a suggestion could it be the inbuilt ND filters doing this and if so can they be turned off. Thanks
Justin
jlboyle
Justin Boyle is offline   Reply With Quote
Old January 2nd, 2004, 03:21 AM   #2
Outer Circle
Welcome, Justin.
2 things to try:
1) keep the sun directly over, behind or off to one side.
2) set exposure correctly with your subject matter.
Old January 2nd, 2004, 11:32 AM   #3
Have you tried adjusting color in post or in-camera under the advanced features?
Tommy Haupfear is offline   Reply With Quote
Old January 4th, 2004, 08:19 PM   #4
Over saturation is one of my gripes when the MX500 arrived in October 2002.
Yow Cheong Hoe is offline   Reply With Quote
Old January 4th, 2004, 08:22 PM   #5
Outer Circle
It's funny that the PV-DV953 doesn't seem to suffer from this. Must be those extra PAL pixels. ;)
Old January 5th, 2004, 08:25 PM   #6
Thanks for all your help guys. but no luck. i had tried these. the only i hadn't tried is shooting away from the sun. wouldn't make any difference as middle of summer in Australia and the sun is right over head burning us all. i don't know the fix for the problem perhaps a polarizing fillter. any ideas guys
Justin
jlboyle
Old January 5th, 2004, 10:06 PM   #7
Outer Circle
With lots of natural lighting, I think this rich color saturation is normal with miniDV cams.
Old January 5th, 2004, 10:50 PM   #8
<<the camera seems to do it more when the sun is bright possibly from under exposure but even when i open it up i can get the right color but the highlights and shadows are not correct and the background becomes over exposed.>>
Justin, this cams are using CCDs. That are small devices which are not perfect by no means. You can't expect everything to be perfect. Even in photography you blow the highlights if you want correct exposure of the main object. After all your audience will more likely to look on the important stuff rather than searching if the shadows were correct.
In bright sun the use of ND4 or even 8 filter is always a help.
Bogdan Vaglarov is offline   Reply With Quote
Old January 6th, 2004, 01:46 AM   #9
Outer Circle
How would a ND filter cut down on color saturation? Just curious.
Old January 6th, 2004, 03:57 AM   #10
I don't mention the ND filter will reduce the saturation.
It'll help for a better exposure and maintaining better brightness/contrast ratio.
Old January 6th, 2004, 04:04 AM   #11
Outer Circle
I also notice a rich color saturation with film, stills and motion, when shot in sunny conditions. So this richness, I think, is normal.
Old January 7th, 2004, 08:43 AM   #12
i just got a website up and running and you will see the oversaturation in the orange flower photo. that photo was a frameshot taken on manual with the aperture open more then on auto with no "bright" light on the object. You may now see what i mean
i might later put on a photo in full sunlight on auto and show you what i mean.
http://www.geocities.com/sniper_y2k2...oto_album.html
jlboyle
