YowCH - MX350 at DVinfo.net
Old January 13th, 2004, 05:26 AM   #1
Outer Circle
YowCH - MX350
I am curious. I've noticed that my MX300 runs very silent. I can barely hear the zoom even with one ear right next to the lens housing. How is the MX350 in this regard?
Also, I've found both the MX8 (PV-DV852) and MX500 (PV-DV953) to be very solidly constructed---does this pretty much sum up the MX350 as well?
Bored and curious in Vancouver.
Old January 13th, 2004, 06:31 AM   #2
Silent.
The MX350 is very very similar to the MX8, MX300 and MX500, probably the same lens assembly.
Yow Cheong Hoe is offline   Reply With Quote
Old January 13th, 2004, 06:45 AM   #3
Outer Circle
Thanks, Yow. There are so many cams that really make a lot of noise which the built-in mics easily pick up. The Optura 200MC was a real buzzer.
I use my DVL9500's quite a bit, but when I use the MX300, I can't hear anything except of the faint muscle of the engine (when recording). That is, when there's no other noise present.
The PV-DV953 runs even more silent---I wonder how that GS100 runs. Tommy?
