ag-ez1 vs 953 at DVinfo.net
Old January 22nd, 2004, 04:58 AM   #1
ag-ez1 vs 953
I own a mx-500 and my dad is in the market for a digital 3ccd camera. I have found one in the paper for cheap an i was wondering if anyone could offer advise. it is written as aj-ez1 however i feel it might be a mispring ag-ez1. does anyone know about this camera. specs etc. is it better or worse than the 500? what is the lense. etc etc.
THanks
Justin
jlboyle
Justin Boyle is offline   Reply With Quote
Old January 22nd, 2004, 06:13 AM   #2
Outer Circle
I gave you a bit of info on the other thread you posted a similar question(s).
I think that overall the MX500 is better.
Old January 24th, 2004, 10:02 PM   #3
there's no firewire port for the ag-ez1, correct?
Langston Sessoms is offline   Reply With Quote
Old January 24th, 2004, 10:45 PM   #4
Outer Circle
From what I recall, no.
Old January 24th, 2004, 11:17 PM   #5
how do you capture using a ez1?
Old January 25th, 2004, 12:16 AM   #6
Outer Circle
You capture like with any other miniDV cam, but if you want to upload it to your computer, you use a deck or another miniDV cam.
Old January 25th, 2004, 12:55 PM   #7
how does the ag-ez1 stack up against the dv852?
Old January 25th, 2004, 01:50 PM   #8
Outer Circle
The EZ1 has about 100 lines less of horizontal playback resolution. There is also a lot of "noise" with the EZ1 compared with the PV-DV852. The EZ1 was a good cam for its day...which was what? 6 years ago, or something like that.
Old January 25th, 2004, 02:30 PM   #9
thanks for the info.
