-   Panasonic DV / MX / GS series Assistant (https://www.dvinfo.net/forum/panasonic-dv-mx-gs-series-assistant/)
-   -   MX500 original accesories? (https://www.dvinfo.net/forum/panasonic-dv-mx-gs-series-assistant/25613-mx500-original-accesories.html)
Marco Mezzalana May 6th, 2004 05:54 AM
Now it's time for another questions...
I've read a lot of thread on wide converter, tripop, microphone etc.
Now I'm very courious about microphne, for short range ?ve a shurec606, but sometimes I would a microphnoe directly linked to the upper connector (I don't now how I can name it), Some people use apex 191, anyone tested the panasonic VW-VMS1? It's cheaper...
In your opinion wich is the best microphone for the mx500? Of course not too expensive...
Bye...
Justin Boyle May 6th, 2004 07:50 AM
heh
well well well. there used to be a lot of topics on this. If you want to get value for money have a talk with frank. He too was asking this question and i dont remember what mic he ended up with was. I have a JVC mic that is not listed anywhere but i am very happy with that. If you look through all the threads you are sure to find something.
Justin
Justin Boyle May 6th, 2004 07:58 AM
heh marco here is a pic of the side profile of my cam. it makes it look !@#$ loads better
http://www.geocities.com/sniper_y2k2000/camera.html
Justin
P.S. if you get another mic for ur cam don't be tempted to carry the cam with it. you might regret it
Marco Mezzalana May 6th, 2004 09:21 AM
Wow so cool...how much it cost this huge microphone?
I think pana mic is very godd, but sometimes (especially during quite scenes) I think it isn't not too accurate, so I'm looking for a mic like your.
Excuse me (sorry there's many difference from english to italian..) but what do you mean "if you get another mic for ur cam don't be tempted to carry the cam with it.
PS with a Hama wide hood your camera looks like a professional camera...
Marco Mezzalana May 6th, 2004 09:48 AM
I perform a search and I found some name, but ther's the same problem...I have to buy it in internet without any test. I must trust forum user tests, but (you can understand me) I not happy spent hundreds of euro without any test...
now this is my wish list at B&H:
Hama wide angle hood (52mm)
Stepup ring (from 43 to 52)
A good mic
I decide to not buy an wide angle converter 'cause its barrel distorsion...
I hope Frank can suggest me a good mic (and why not?even a good hood...)
Marco "the doubtful"
Frank Granovski May 6th, 2004 03:19 PM
A good mic? Pana's stereo zoom mic improves audio somewhat. I decided to go with a cardioid, one which is 1/2 way between a cardioid and hyper-cardioid, in terms of pattern. That mic is the Apex 191. It' costs $99 Canadian, which is about $72 US. The shock mount for the hot-shoe is the Sennheiser MZS6 that I use for the Apex. You will need a short (1-foot) XLR to 1/8" plug adaptor, and a foam rubber thingy of just "fluff" to cover the mic---softens the audio.
Marco Mezzalana May 7th, 2004 12:18 AM
Someone purchase azden ECZ-990, Have you tested it? I consider that because I can found it at b&H photo, so I coul order this mic, a lens hood, ad a tripod, in this way if I have to spent 30€ in shipment cost I do it one time only...
I search apex, but it's very hard to find it in europe...
Frank have you a hood attached to your camera, if yes wich one?I found this: 52mm Screw-In Plastic Wide Angle Lens Hood with Cap at b&H.
Last question (excuse me), at b&H I found this tripod: bescor TH-650 Industrial High Performance Tripod with Fluid Head - Supports 11 lbs...it sound like a good system, do you agree?
Thank for your support Marco
PS I try to insert a web link but I was not to be able to do it sorry!
Frank Granovski May 7th, 2004 12:56 AM
I've now only used the Apex twice, on my MX300.
Re: "Frank have you a hood attached to your camera." - There are hoods on all my cams/lenses. Rubber hoods.
Re: "I found this: 52mm Screw-In Plastic Wide Angle Lens Hood with Cap at b&H." - Why not get a 43mm rubber hood?
Re: "bescor TH-650 Industrial High Performance Tripod with Fluid Head - Supports 11 lbs...it sound like a good system." - I don't have a clue. I rather like Manfrotto 'pods/heads (sold as Bogan in the USA).
Justin Boyle May 7th, 2004 01:09 AM
Marco what i was meaning is that if you carry the cam by the mic there is a chance that it might break ur mic. they aren't designed as a handle. it used to work well for me till one day it broke off so now it is glued up.
Justin
Marco Mezzalana May 7th, 2004 01:23 AM
to frank: Thank you so much, very useful suggest, you're right why not 43mm rubber hood, I think I'm stupid sometimes...but you get a wide angle hood?And if I want connect a UV-protector filter I can do it?
I will get some information for the mic...
to justin: ok, I've understand now, but you can be sure I carry my cam only in the right way...
Frank Granovski May 7th, 2004 03:07 AM
but you get a wide angle hood? And if I want connect a UV-protector filter I can do it? I will get some information for the mic
It depends on the wide angle adaptor, concening if you can screw on a filter to it. Raynox and Tiffens come with front filter threads while the Pana wide does not. If you want to put on filters you should get the expensive, ultra thin 3mm Hoya, the one with threads on both sides, so you will have the option of screwing on a hood to the filter. The hood is more important than the UV with a wide angle lens. Thicker filters will more easily cause vignetting on a wide. The hood is to block unwanted light causing streaking, but a hood will also protect the lens and lens housing somewhat. B+W make good rubber hoods for wide angle lenses.
Regarding the mic, I can give you a Canadian website that sells Apex mics. (The 191 is $99 Canadian.) Bryan Beasleigh turned me on to this mic after he did a bunch of research and tests. If you make a search for this mic in the audio forum (Now Hear This), The Apex 191 will pop up several times at least.
Keep in mind that the Apex 191 is not a directional mic. It picks up sound in an oval pattern pointing forward, from the sides of the mic and the front. This was one of the type of mics I wanted, to pick up a wider range of surrounding sounds opposed to zooming in a specific sound. The other one costs too much money for me and is a way too big for my small cams.
Marco Mezzalana May 7th, 2004 03:23 AM
really thanks, now I search for apex...I consider to post a thread in audio section...
Bye
Guy Bruner May 7th, 2004 05:59 AM
Marco,
If you are interested in the Hama rectangular hoods, take a look in the DV953 album on my website. I have a 52mm Hama hood that attaches to my DV953 with a 43-52mm stepup ring. By the way, the description of this hood at B&H is incorrect. It is not a screw on hood. It is a clip on. If you are still interested, I suggest getting the 55mm hood. It should clip onto the outer flange of the MX500's stock hood, right in front of the focus ring which would eliminate the need for a stepup ring. I have only eyeballed this, though. You might want to measure the outer diameter of the stock hood to make sure it is 55mm before you buy one. Due to the way these hoods are made, you can't put a filter behind them unless you screw a stepup ring into the filter and then clip the hood to that.
Marco Mezzalana May 7th, 2004 07:32 AM
I found ispiration from your site for hama hood...yes my mx500 have its hood with the external diameter of 55 mm, so I will attached the hama to the original panasonic hood correct? could it be damaged? If I want to use the same hood with another cam, such as nv-ds28 what I need? The nvds28 has 37mm lens diameter but the outer flange is 43mm...so the clip will be attached to an external stepup ring wich 37-43mm, right?
thanks
Guy Bruner May 7th, 2004 08:06 AM
Marco,
If you want to use the hood with both the MX500 and the DS28, I would use a 37-55mm stepup ring on the DS28. You can't mount a stepup ring to the outside of the flange on it. I don't believe mounting the hood on the outer flange of the MX500 will damage it. But, it is a press on fit with a clamp, so any grit or dirt might scratch the flange.
Marco Mezzalana May 7th, 2004 09:57 AM
Ok I've all the information, I will be careful to mount hood after cleaned the flange to avoid any scratch...Only one thing it's dark, if this hood is a press with a clamp, how can screw it in the stepup ring?
I've take a look to your album picture but I still don't understand ...could you send me some (little) picture with a detail, thanks for your patience!!!!
Guy Bruner May 7th, 2004 04:21 PM
Marco,
I'm leaving town for a holiday here. I will have to take some pictures later. But, the Hama has no screw threads on it. The mounting ring has slits to make it easier to push on over the outside diameter of a stepup ring or the flange on the MX500. There is a toggle clamp that looks similar to a hose clamp for an automobile. You push the toggle down and it draws a band tight around the outside of the hood to keep it affixed to the flange.
Marco Mezzalana May 8th, 2004 05:05 AM
Ah ok, I'm going to understand, when you can, I'm very happy if you send me some photos...A friend this holiday goes to Dan Francisco I hope she found these devices so I can save shipping and cost money...
Guy Bruner May 8th, 2004 04:22 PM
Marco,
I have posted 12 new pictures in the Hama Hood album pages 2 and 3 that show how the locking mechanism fits onto a stepup ring. This is also how it would fit onto the outer flange of your stock hood. Note that you will not be able to use a filter behind the hood if you install it onto the flange of your stock hood.
Marco Mezzalana May 9th, 2004 06:24 AM
Really thanks, very very intersting, now I've understand...I think I will order this device...I hope taxes beetween Usa and Italy aren't much expensive...
