GS400 WideAngle lenses - Page 2 at DVinfo.net
Old September 2nd, 2004, 02:46 AM   #16
Errrr, why do you need 2 lens hoods?
Guy, would it cause any scratches on the flange of the built-in hood of the Pany if the rectangular Hama is clipped on to it? I hate scratches :-) That's a pretty cool looking hood!
Allan Rejoso is offline   Reply With Quote
Old September 2nd, 2004, 06:38 AM   #17
Why I need two hoods?
I don't really know, but it's always nice to have something to chose from. ;-)
Stian Bakkane is offline   Reply With Quote
Old September 18th, 2004, 12:31 AM   #18
Just put a Bower super wide angle on my GS-400 at the Sawgrass mall in Ft. Lauderdale...............It vignettes at wide open but looked clean thru LCD ........They wanted $320 I beleive it was a .490......More info soon!
Marty Stonely is offline   Reply With Quote
Old September 18th, 2004, 12:31 AM   #19
Old September 19th, 2004, 09:35 PM   #20
vignetting in card mode
Hi,
vignetting is the black area in the 4 corners, right?
I've tested the Vitacom .5x wide angle lens on the GS400. Didn't see any vignetting in video mode but when I switch to card mode, I see it at 1x. When I zoom to 2x, not more vignetting.
Question:
* What are the benefits of the wide angle lens besides
providing a wider angle view and letting more light into the
camera?
* Should I leave the side angle lens attached at all times? Seems
troublesome to take it off and on all the time.
* With the vignetting effect in the card mode, I would prefer to
use the wide angle lens only in video mode. Any suggestions?
Alvin Tan is offline   Reply With Quote
Old September 19th, 2004, 09:51 PM   #21
$320...WHEW! That's a chunk of change! My Kodak Ektanar was only $40 and it doesn't vignette.
Alvin, a wide angle does not let in more light but it does provide an increased field of view. Leaving it on all the time is a matter of preference. If you shoot a lot of close up videos, then maybe leave it on.
Guy Bruner is offline   Reply With Quote
Old September 19th, 2004, 11:29 PM   #22
Thanks guy.
Any idea why vignetting only happend in card mode
and not video mode?
If not for this problem, I would leave it on all the time. Come to think of it, if I only intend to tape video but not photo snapshots, then it would be ok.
Old September 20th, 2004, 06:19 AM   #23
The GS400's field of view is wider in card mode than in video mode (37.6 degrees vs. 44.5 in video).
Old September 21st, 2004, 01:39 AM   #24
Yes, it's using more of the chip's surface area in the stills mode than in video mode, which makes for wider wide-angles using the same focal length lenses.
Note that although a wide-angle converter ''sees more'', it's also useful for its perspective control, where items close to the camera are given more prominence that those further away. A bit like the reverse of telephoto compression if you like.
Also note that fitting a wide-angle converter will lose you a bit of light. Not much, but if you're down on your knees in the gloom, take off converter lenses, filters and stick to the wide end of the zoom.
tom.
