GS400's Pro-Cinema or do it in post? - Page 2 at DVinfo.net
Old September 20th, 2005, 12:27 AM   #16
OK, here are my test. The results of some of the tests revealed how this stuff works and how a better set of tests might be run. More coming soon.
http://www.matterofchance.com/gs400/latitude.html
Also, there is more discussion on this topic here.
Owner/Operator, 727 Records
Co-Founder, Matter of Chance Productions
Blogger, Try Avoidance
Joshua Provost is offline   Reply With Quote
Old September 20th, 2005, 01:14 AM   #17
Hi Joshua,
Thank you very much.
You are brilliant.
Regards
Leigh
Leigh Wanstead is offline   Reply With Quote
Old September 22nd, 2005, 06:29 PM   #18
Joshua, you sure did a thourogh test, it is very enlightening, Thank You!
Paul Kepen is offline   Reply With Quote
Old September 24th, 2005, 10:59 PM   #19
Hi Joshua,
Do you know zebra in GS400 is 100% based or 70%-80%?
TIA
Regards
Leigh
Old September 24th, 2005, 11:15 PM   #20
Leigh,
It differs depending on mode (NORMAL vs. PROCINEMA / PICTURE ADJUSTMENT or not). In NORMAL it's 100%. In PROCINEMA, I believe it showed as 110% in one of my tests. With PICTURE ADJUSTMENT set to CONTRAST -5, it showed up at 85% in NORMAL and PROCINEMA.
Josh
Old September 26th, 2005, 12:09 PM   #21
Leigh,
Josh
Hi Joshua,
Thanks for the answer.
May I ask how you test and get these numbers? Just curious and I want to test to get these numbers myself?
TIA
Regards
Leigh
Old September 27th, 2005, 08:00 AM   #22
Leigh,
You can light up white card, frame it up, and open the iris until you start to see zebras. Record a second or two, bring it into an NLE and pull up a vectorscope. It should show you the IRE levels. I've done this with Premiere Pro 1.5. I did this in all the modes described, but I rushed, so I can't stand behind the figures, but I'd be interested to see if you come up with the same.
Josh
Old September 27th, 2005, 01:24 PM   #23
Hi Josh,
Great
I will try tonight.
Regards
Leigh
Leigh,
Josh
