NV-GS300 AV in DV out at DVinfo.net
Old April 23rd, 2006, 03:43 AM   #1
We have set up low cost arrangement for a two camera studio for live streaming . We are using three NV-GS300 cameras, two connected via AV to a crunch switch and one on the other side of the crunch switch to convert back to digital for the live feed. Sound is added at the converter. Previously in our tests, we used a Sony camera to receive the analogue input and it worked fine.
I am confused about the settings required for the NV-GS300 to work in its place. I know it should be in playback mode but the manual is pretty short on detail about this.
Obviously, this is only ashort term solution.
Anyhelp to get me out of this bind wouldbe gratefullyaccepted.
With thanks,
Damian Hickey
Damian Hickey is offline   Reply With Quote
Old April 23rd, 2006, 06:45 AM   #2
The GS300 does not have AV In.
Guy Bruner is offline   Reply With Quote
Old April 23rd, 2006, 09:37 PM   #3
Getting to a solution
Dear Guy,
Thanks for the confirmation. We used an old Sony 3 chip as a replacement and it worked fine.
Cheers,
Damian
