Which brand of tape do you use with your MX 500? - Page 2 at DVinfo.net
Old May 8th, 2003, 09:45 PM   #16
And about storage, I have said this before, do not put into a dry box, that's too dry, the tape turns brittle when over dried.
I suggest using silica gel in an air-tight box, to remove excessive humidity, and prevent fungus growth. There is no need to change the gel when they turn pink unless the box is opened. Tunring pink means that the gel is doing its job. Only change the gel if you open the box and let in fresh and wet air.
Yow Cheong Hoe is offline   Reply
