Who all here had problems with the DVX100's heads? - Page 2 at DVinfo.net
Old July 2nd, 2003, 07:19 PM   #16
Peter, the thing is I wasn't just getting droppouts...my footage was ALL messed up! Plus I was getting the flashing red X which means dirty heads?! Drop-outs would be a godsend for me compared to my problem. Hopefully runing the cleaner and switching to MQs will fix it. They are due to arrive tommorrow from UPS. I'll keep you guys posted.
Glen Elliott is offline   Reply With Quote
Old July 2nd, 2003, 09:36 PM   #17
These dropout problems are starting to scare me:(
I just spent some hard earned cash on a new DVX100 and now I'm having doubts! Do you think this could be a major problem ??
Nick Medrano is offline   Reply With Quote
Old July 2nd, 2003, 09:38 PM   #18
Space Hipster
It's not a widespread one. Hundreds, probabably thousands of these are out there, several features and dozens of shorts and docs have already been shot with the cam without this issue showing up as "major problem".
stephen v2
www.insaturnsrings.com
Stephen van Vuuren is offline   Reply With Quote
Old July 3rd, 2003, 10:02 AM   #19
its strange thou, as i have major probs with one of my MX500's having dropouts and distorted audio and video...
BUT after runnign tapes continually, it sems to have stopped teh problem..
I always thought it was the heads that neede lubing from teh tape... as after i ran the cleaner, it worked perfectly...
I gather these 2 cams are running the same DVMechanism considering teh size....
i still havent seen this pop up on the DVX thou..
hope it doesnt...
Peter Jefferson is offline   Reply With Quote
Old July 3rd, 2003, 12:06 PM   #20
Nick--I woudln't worry too much about the dropouts. Just be sure to use MQ tapes only, def. not something you want to skimp on. I haven't seen anymore dropouts in my stuff, so maybe it's problem solved. A hunch is that part of this is related to the "break in" of the camera, and when using MQ tapes, whcih are "dry lubricants" maybe there is some issue with enough lubrication getting on the heads in the initial break in period. Honestly, I have no idea, just a guess. Anyway, you can find MQ tapes at www.edgewisemedia.com. They carry them for around $5.50 a tape, which is BY FAR the cheapest I have seen.
Peter
Peter Richardson is offline   Reply With Quote
Old July 3rd, 2003, 12:08 PM   #21
Glen--It sounds like the problem was the tapes to me, but that's just a guess. Heck, if I've been using the exact perscribed tape from Panasonic and still have intermittent problems, then maybe this cam is just really sensitive to tapes. ANyway, I think the MQ's may be the answer. How much did you pay for yours? I found them at www.edgewisemedia.com for about 5.50 per tape. Any better deal?
Peter
Old July 8th, 2003, 07:15 AM   #22
Geezz, I'm buying a DVX100 today and I sure hope I don't have anyh of these problems!! If it's a lemon I'm taking it back!
Best Regards,
Mark T. Monciardini
Riverlight Studios
www.riverlightstudios.com
DVX100/Final Cut Pro 4/Mac G5 Dual 1.8
Mark Monciardini is offline   Reply With Quote
Old July 8th, 2003, 07:19 AM   #23
Make sure you shoot only with Panasonic MQ tapes right off the bat!
Old October 26th, 2003, 09:40 PM   #24
Glenn- I hope you are still receiving subscriptions to this topic. Did the MQ tapes solve your problem? I am having the same issues as you intitially reported...
Also- how long did you run the cleaning tape in the camera to clean it?
Ted
Ted Banucci is offline   Reply With Quote
Old October 27th, 2003, 05:23 AM   #25
Warden
You must follow the directions on the cleaning tapes exactly. Any deviation from the printed instructions could potentially damage your camera. Do Not clean for more than the recommended time or run the tape more than the directions say.
Jeff Donald
Carpe Diem
Old October 27th, 2003, 06:26 AM   #26
bit of an update following jeffs revival of this, i have found that even using the standard consumer DVM60 tapes does NOT cause a problem IF you FF and RW the tapes...
now this works for me, so i use ye ol DS88 handycam to do this...
I have shot about 80hrs continuously with no dropouts since i started using this method on both the MX500 and DVX.
I have now got my hands on the MQ tapes as business has now started to really pick up.
Even though i am not getting drop outs anymore, i am still wary, and considering the clas of this cam, the extra investment is worthwhile
Old October 28th, 2003, 07:53 AM   #27
My AG-DVX100 has only 15 hours on the counter, and this week I had some problems (dirty heads). I use FUJI tapes. I will try JVC tapes today, it's impossible to find Panasonic MQ here in Europe.
Marc Martin is offline   Reply With Quote
Old October 28th, 2003, 12:24 PM   #28
hey guys--Well I have used ONLY MQ tapes in my cam and I STILL had problems with tape dropouts, but they seem to have subsided now. Bottom line, I'd say use MQ for reduced headwear, but don't think that simply switching to them will solve all your problems, as I obviously still had problems with them.
Peter
Old October 29th, 2003, 04:46 PM   #29
<<<-- Originally posted by Peter Richardson : hey guys--Well I have used ONLY MQ tapes in my cam and I STILL had problems with tape dropouts, but they seem to have subsided now.
Peter -->>>
Are these dropouts occuring on normal speed playback or high speed review/cuing? I find that some capture programs (like Scenalyzer) are tough on tape transport mechanisms. Apple's iMovie seems to be the gentlest.
Besides the Panasonic MQ tapes (which they obviously recommend since they manufacture both the camcorder and the tape), why should Sony tapes be bad for the DVX100? I've never had problems with Sony on the PD-150. I like sticking with one brand, and will do so when I get the dvx100 next week, unless someone has solid experience to the contrary.
Marc Young is offline   Reply With Quote
Old October 29th, 2003, 07:41 PM   #30
Marc,
It doesn't have to do with the tape brand/quality. It has to do with the camera. I've always used TDK tapes just fine in my GL1, even switching tapes. But when I use them in the DVX100, the camera takes a crap all over the tape. Just because your Sony tapes work in your PD150, does not mean that they will work in the DVX100.
And this does not refer to playing back the tape (in reference to your commment about iMovie). It has to do with recording the tape. The camera leaves horizontal stripes all over the recording which is unsalvable.
Ted
