low light versus pd150 - Page 2 at DVinfo.net
Old July 22nd, 2003, 08:31 PM   #16
Barry Wan Kenobi
<<<-- Originally posted by Stephen van Vuuren : Andre:
At 0db gain in interlaced vs a PD150, I agree, that would reveal results worth looking at.-->>>
In the link I posted, there is a comparison picture between the two cameras at 0db gain.
Old July 22nd, 2003, 08:49 PM   #17
Space Hipster
Beale's site has good stuff on it, but it's at 1/48th shutter. I find you can get good results at 1/24 shutter (my low lights here are at 1/24th) and most very low light shots don't need higher shutter speeds.
So that shot would look quite different at 1/24th.
stephen v2
www.insaturnsrings.com
Stephen van Vuuren is offline   Reply With Quote
Old July 22nd, 2003, 11:45 PM   #18
Barry Wan Kenobi
True, but if you start dropping shutter speeds, the VX2000 can go down to 1/4 or slower... and that will give you a dramatically brighter picture! So, the only true apples to apples comparison is DVX interlaced at 1/60th, vs. VX2000 interlaced at 1/60th. Comparing 24P vs. the VX2000 is pointless.
Old July 23rd, 2003, 08:51 AM   #19
Space Hipster
I'm not sure about the VX2000/PD150, but on my old XL-1, "slow shutter speeds" were a digital effect. 1/60th and faster speeds were on one menu and produced a "natural" shutter speed, i.e. without stuttering/strobing.
However, the slower speeds was under the digital effects menu and while they worked, the resulting image was extremely akward and only usable on still shots.
I find no such effect with the 1/24th speed on the Panasonic, just increased motion blur.
How do the slow shutter speeds work on the Sony cams?
stephen v2
Old July 23rd, 2003, 12:59 PM   #20
Barry Wan Kenobi
Using the slower shutter speeds on the PD150/VX2000 involves dropping fields, and posterizing time. Shooting at 1/4 means you'll get four distinct images per second, so it sounds similar to what you experienced on the Canon. Choosing 1/30th provides a filmish blur to the image, and 30fps motion, at the expense of losing half your vertical resolution.
Old July 23rd, 2003, 02:31 PM   #21
Stephen, if you go for 1/24 (near 100% optical dutycycle) are you then still trying to get "film look". Not only extra motion blur but also (reduced) temporal aliasing effects which film look supporters like so much (strobing, shakiness...)will be reduced.
Andre De Clercq is offline   Reply With Quote
Old July 23rd, 2003, 03:44 PM   #22
Space Hipster
Andre:
Not sure that I understand your question. 1/24 gives more motion blur, but if you follow film guidelines for panning, motion, footage has looked fine for me.
Barry:
Thanks for the info. I would officially declare the DVX100 the 0db low-light champion of the world (insert echo, delay) with it's 1/24th shutter speed.
stephen v2
Old July 24th, 2003, 06:13 AM   #23
Agree Stephen, but as far as i can follow the "film look" believers, they exactly want (need) the reduced motion blur, strobing,...just like it is visible in real film with its 1/48sec (50% dutycycle) shutter properties.
Old July 24th, 2003, 08:08 AM   #24
Space Hipster
That would be for zealots only. Having started shooting film, mostly super 8mm and some 16mm, I did use other shutter speeds at times other than 1/48 if the cam offered them.
It looks different and different cams used different shutters but the motion blur comes more from 24fps than shutter speed. 60 fields a second gives a very different temporal feel to motion and that why I think frame rate is the #1 issue with film look, shutter speed would be well down the list.
stephen v2
