Strange horizontial lines on LCD at DVinfo.net
Old August 18th, 2003, 07:45 AM   #1
hmm.. i havent touched the DVX for about a fortnight, so i took it out this evening for a little messing with and i noticed that there were slight regular "bumps" on the lcd display footage....
Were talking perfect lines thruought the whole screen, in order ...
the dots represent the lighter tones.. but this is what it looks like..
footage isnt afected thou...
now im no lcd expert, but when it warmed up a little, all was well...
anyone know if this is a potential problem with these units?
Peter Jefferson is offline   Reply With Quote
Old August 18th, 2003, 01:38 PM   #2
Outer Circle
That's really strange. Maybe it's normal; maybe it's not. Why not e-mail Pana AU to see if it is normal (or not)?
Click here for a fast Pana response
stuartc@panasonic.com.au
Old August 19th, 2003, 06:13 AM   #3
wierd...
i dunno if i can email him, but ill give it a shot....
its only when the unit is initially powered up after a short while it goes away, then when i power down, you can still see some burning in the screen which fades after 15 secodns or so...
i duno if its a voltage thing???
I only notice it when in extreme low light... normal shooting and everythign looks fine...
