-   Panasonic DVX / DVC Assistant (https://www.dvinfo.net/forum/panasonic-dvx-dvc-assistant/)
-   -   Wear on DVX100 Heads (https://www.dvinfo.net/forum/panasonic-dvx-dvc-assistant/14622-wear-dvx100-heads.html)
Darrell Hinton September 16th, 2003 08:58 PM
Hello, I own a DVX100 and have recently been thinking about getting a cheap consumer miniDV camera to decrease wear on the DVX heads. I don't know much about this topic, only what I have read on these forums. I was wanting to know how much extra wear using the DVX as a capturing device cause the heads? Is it major wear or is it really just miniscule wear that could add up and cause problems over time? If I am only capturing once a week or so is there any hurry to get a new device to capture on or will I be okay as long as I am not capturing heavily with the DVX? Also, how much does it cost to replace the heads on a DVX? I've been thinking about getting the JVC GR-D30 miniDV cam for capturing (because it is the cheapest miniDV camera out there that has stereo sound). Is it not a good idea to mix the footage taken from the DVX with a cheap JVC cam or should I just quit being a cheapskate and pay the extra $50-100 to get a Panasonic brand camera?
Frank Granovski September 17th, 2003 01:01 AM
The more you use a cam, the faster you'll wear the heads. Personally, I don't worry about it. If they wear, I'll just get them replaced. As for the cost of getting the DVX heads replaced, perhaps e-mail Pana Pro.
Darrell Hinton September 21st, 2003 05:01 PM
Well, I e-mailed Panasonic 4 days ago about how expensive it is to get the heads replaced for the DVX100 and still no reply. Does anyone know at least an approximate price for how much this would cost? Any help would be much appreciated.
Jeff Donald September 21st, 2003 05:45 PM
Ballpark figure, between $300 and $600 USD. But you've got to remember, a ballpark is a pretty big place.
Darrell Hinton September 21st, 2003 06:30 PM
Thanks Jeff. I see what you are saying, I was just wanting to make sure it wasn't extravagantly expensive (like $1000 or over). I'm having a hard time deciding on wether I should get a cheap-o cam for capturing or not. I would get one without question if I didn't need so many other things too(because I usually go by the "better safe than sorry" philosophy). Unfortunately, I still need to purchase a good mic (probably an ME66) and a good tripod(which will probably be atleast another $300, I'm just using my old cheap-o tripod right now because I'm not shooting anything important yet, just been messing around figuring stuff out about the DVX). I will be begin shooting my first short at the end of October, so I think a good tripod and mic should probably come before the extra cam for capture. Thanks a lot, you have all been very helpful, as usual.
Jeff Donald September 21st, 2003 06:43 PM
I think your camera will go out of style (technologically speaking) before you wear out your heads.
Darrell Hinton September 21st, 2003 07:00 PM
If that is true, then I will probably not be getting a capture cam. Although, I do plan on using my DVX for as long as it will hold up(or atleast until something else comes out with features that are just too hard to resist), if it will take that kind of time before the heads will wear out, then I probably won't mind dishing out the money to replace the heads when that time comes. Thanks again Jeff.
Randy Reyes September 22nd, 2003 03:51 AM
If I were to shoot some 24p footage on the DVX and use a cheaper camera as a DV deck, would that cheaper camera fully retain and transfer all that 24p footage to the computer? Thanks!
Peter Jefferson September 22nd, 2003 06:16 AM
yes, i alwyas run a backup thru a small DS88 connected thru firewire (cam to cam) when shooting important stuff.
other times, i run a sync config from the dvx and allow it to trigger the DS deck when the DVX tape is coming to an end. Basically i can swith tapes while continuing to record...
this is good for those long and tedious wedding ceremonies which never seem to end...
oh and it doesnt matter as all your footage is identical...
the 24 function is the pulldown config, our tape STILL physically runs normally
