Shooting Outdoors Settings at DVinfo.net
Old December 1st, 2003, 11:47 AM   #1
Hello,
I'm going to test out my new DVX100 and take it outdoors and film around the city just for kicks. What settings do you guys recommend? Should I film at 24P/A? Thanks!
Dan Lahav is offline   Reply With Quote
Old December 1st, 2003, 11:59 AM   #2
Guest
Posts: n/a
The question is what type of software do you have on your computer to import the project. Using 24a you need either Avid, Vegas or FCP4 for the 2:3:3:2 pull down.
Other than that if you do not have these apps go for 24p.
Old December 1st, 2003, 12:00 PM   #3
I have premiere, after effects and vegas
Old December 1st, 2003, 12:11 PM   #4
Guest
Posts: n/a
The you can use 2:3:3:2 pull down with Vegas if you use 24a.
I would try it and see what you get as 24a does shoot beter for the film look, however do remember lighting.
