-   Panasonic DVX / DVC Assistant (https://www.dvinfo.net/forum/panasonic-dvx-dvc-assistant/)
-   -   Evening night shot effect with the DVX (https://www.dvinfo.net/forum/panasonic-dvx-dvc-assistant/18208-evening-night-shot-effect-dvx.html)
Stefan Scherperel December 21st, 2003 03:06 PM
Ozan biron was pretty close. All you need is a good 35MM slr, good tripod, chalk and a measuring tape. I went down to a street corner at about 7:30pm and took my measuring tape and measured about 15ft across this corner. I then made marks with the chalk starting every 1/4 inch, then 1/2 inch and finally going up to about 2 inches. These marks were basically tripod placements. I wanted it to ease in and out hence starting with teh quarter inch. I had two identical lines for two of the tripod legs, this let me keep the camera pointed in a single direction. I used 100ASA Kodak gold with a 35 sec exposure on each frame. This was kind of a test so next time I want to use a dolly to get a much smoother motion. I'm a digital artist at a local photography store, so I got my film developed for free. I think I used 5 rolls alltogether. I then scanned each frame and imported them into after effects 6. I used the steady move plugin (without zoom) to smooth out the motion. I made each frame about 15% larger than the 720x480 so that the steady move plugin would not lose any resolution when evening out my footage. So that's my secret, I hope this helps. By the way it is a slow and tedious process, so make sure you have lots of time on your hands. It took about 2 1/2 hours to film and about another 1 1/2 for the after effects work, all for a 5 second shot.
Joe Romano December 21st, 2003 11:37 PM
Thanks, I appreciate the reply and I appreciate your skill and cleverness in working all that out.
Joan d'Arc December 23rd, 2003 12:53 PM
Obtaining this effect in video is impossible. Try using a Nizo super8 camera. It's perfect for this kind of job and gives a superb quality.
Ozan Biron January 9th, 2004 09:59 PM
AH HA! Ive done it!!! "It is possbile"
Take a look of my VIDEO test i did with my 100a... still needs a little tweaking but gives the same effect as film!
Take a look...
http://www.illconcepts.com/videotest.mpg
Dan Lahav January 11th, 2004 12:56 PM
care to tell us how u did it? can i do that with my dvx100 (no "a")?
Imran Zaidi January 11th, 2004 01:46 PM
Wow, that is definitely a nice effect. Do tell!
