Chroma Level, Phase and Master Ped. at DVinfo.net
Old January 12th, 2004, 05:03 PM   #1
Hey Everyone,
I have recently purchased the DVX100 and I am not sure what some of these settings are and how they effect the picture.
What is Chroma Level, Chroma Phase, and Master Pedestal?How does this effect the picture? What setting do you guys find best?
Thank you very much for you help.
Matt
Matthew Phillips is offline   Reply With Quote
Old January 12th, 2004, 05:57 PM   #2
Space Hipster
Matt:
Congrats on your DVX - if you search here, you will find lots of discussions on these items.
To learn the camera settings, hook the camera up to a very high quality monitor (and to a computer via firewire that has software with waveform or vectorscope). If you don't know what a waveform or vectorscope is, you need to speed some time reading up on video signals (try www.greatdv.com and www.adamwilt.com).
Once hooked up, adjust each of the settings, one at a time, through it's full range until you see the effects of the control.
stephen v2
www.insaturnsrings.com
Stephen van Vuuren is offline   Reply With Quote
Old January 12th, 2004, 08:52 PM   #3
Chroma level adjusts chroma saturation
Chroma phase adjusts the hue
Master Ped adjusts master pedestal (black IRE level and white IRE level), increasing or decreasing recorded signal level.
From an interesting article on http://www.videosystems.com/
FOR EVEN MORE INFO
check out www.dvxuser.com
John Hudson is offline   Reply
