Mic Gain Setting? at DVinfo.net
Old March 5th, 2004, 11:45 AM   #1
Mic Gain Setting?
Anyone know how the Mic Gain should be set for a Sennheiser ME66 and Panny MC100 (-50dB or -60dB)? I'm blind. I can't find it in the lit. Thanks, Grant
Grant McClintock is offline   Reply With Quote
Old March 6th, 2004, 01:58 AM   #2
Should work with either setting but if you feel your levels are too low on playback switch to -60db. It's a significant boost from -50.
Preston Herrick is offline   Reply With Quote
Old March 6th, 2004, 07:57 AM   #3
Thanks, preston. Those are instructions even I can follow. Grant
