Anyone using this camera for underwater? at DVinfo.net
Old June 7th, 2004, 05:02 PM   #1
I'm considering this camera for underwater video. I was hoping someone else may already be...and could give me thier opinion on its performance.
Bryan
Bryan Coleman
Santa Cruz CA
Bryan Coleman is offline   Reply With Quote
Old June 17th, 2004, 11:33 PM   #2
One of my uses for the DVX100 is for chasing sharks.
Some tests off Catalina showed great promise.
Steve Rogers is offline   Reply With Quote
Old July 8th, 2004, 03:36 PM   #3
Can I just mention that if you are going diving off of Santa Cruz you will have about 8 feet of vis in 50 degree water? No camera is going to perform well over another in those conditions! :D
I've considered getting an enclosure for my DVX 100, but figured it would be a lot less expensive if I were to take my Canon Optura 300 and damage would happen to it. Also I'm sure it will be much more manuverable in the water with it's size.....
Good luck!
Ted Banucci is offline   Reply With Quote
Old July 11th, 2004, 06:25 PM   #4
I know you're looking for people here that have used the cam underwater. While I have not, I am pretty sure I've seen it used above and underwater on MTV's WildBoyz. You could check it out to see some footage.
Jesse Bekas is offline   Reply
