lense sizes at DVinfo.net
Old November 7th, 2004, 09:40 PM   #1
lense sizes
I just bought a dvx-100a and I also purchased some extra lense filters. These filters are 62mm and used with an adpter sizing ring. Now when I look through them, my view is circular. I also got a .5x wide angle lense than has a very similar problem (its view is football shaped). Can this be fixed or shall I return these lenses?
Larry
Larry Seymour is offline   Reply With Quote
Old November 7th, 2004, 10:00 PM   #2
Barry Wan Kenobi
Sounds like you got "Digital Optics" lenses. Definitely return them, they don't work with the DVX and they're very low quality.
Old November 8th, 2004, 01:18 PM   #3
the filters are"Crystal Optics" and the wide angle is "Digital Optics". I take it I should also return the "Crystal Optcs"?
thanks for the fast answer!!
Old November 8th, 2004, 02:04 PM   #4
Barry Wan Kenobi
By all means. That stuff is *not* quality. Hope you can get your money back...
Old November 8th, 2004, 03:02 PM   #5
thanks
Old November 9th, 2004, 10:08 AM   #6
It sounds like you're describing vignetting, where the edges of the frame receive less exposure that the centre - and in extreme cases where the edges of the frame don't show the picture at all. If you've got a 72mm filter thread (you have) make sure you buy filters and converter lenses that are designed for that attachment size or larger. It's OK to use step-up rings (72mm to 78mm, say) but not step-down, and especially so with wide-angle converters.
tom.
