DVX200 auto shutoff at DVinfo.net
Old January 2nd, 2017, 11:26 AM   #1
DVX200 auto shutoff
Hi,
My DVX200 powers down after 15 minutes if not used ... I don't see anything in any manuals about changing this. Is it changeable?
Paul Luft is offline   Reply With Quote
Old January 3rd, 2017, 05:32 AM   #2
Re: DVX200 auto shutoff
There are two menu settings under "Other Functions",
"Economy (Batt)", which saves the battery after 5 minutes of no operation. It can be set to "ON/OFF".
"Economy (AC), whcih turns the camera off after 15 minutes without any operation. It can be set to "On/Off".
There are a few exceptions, where the camera is not switched into the power saving mode. It is described on page 177 of the English manual.
Regards,
Joachim
Joachim Claus is offline   Reply
