Test shoot for the DVX -100 pal cam at DVinfo.net
Old February 7th, 2003, 05:11 AM   #1
I am planning to shoot a three minute test on the new DVX -100 to be transferred to film . Its for a 90 min feature ( mostly indoor) to be fimed in March , I want to buy the camera so this test is a deciding factor , the film is going to be released on 35mm . any suggestions?
PREETHA
Preetha Jayaraman is offline   Reply With Quote
Old February 7th, 2003, 06:41 AM   #2
Outer Circle
Yes, I have the most important suggestion for you. Before you shoot a 3 minute test with a PAL DVX100, check with the transfer lab about requirements. Example, interlaced or progressive? Shutter settings---locked iris, etc. Also, read that film look article at http://www.dv.com
Old February 8th, 2003, 01:38 AM   #3
Thanks for the info . I will send an email out to them immdly.
PREETHA
Old February 22nd, 2003, 12:11 PM   #4
HDV Cinema
<<<-- Originally posted by Frank Granovski :Also, read that film look article at http://www.dv.com -->>>
Just to be clear -- the settings for creating a "film look" is the typically NOT what one needs for going to real film.
Old February 23rd, 2003, 05:16 AM   #5
Transfer to film...
According to what you've said it seems to be that progressive video may not be the best one for transferring to film...and also achieving the film-look isn't the the best choice to it...
I had thought 24p and film-look was mainly targeted to film tranfers.
What's the use of 24p and film-look then?
I'm in a fog
doncart
Felipe Matilla is offline   Reply With Quote
Old February 23rd, 2003, 06:27 AM   #6
Outer Circle
Re: "Just to be clear -- the settings for creating a "film look" is the typically NOT what one needs for going to real film."
The article also has info about film transfers.
Felipe, some transfer labs do a better job with progressive, others, interlaced. Check with the transfer lab you intend to use.
