Old analog small clip in 24fps quick/HD at DVinfo.net
Old May 8th, 2003, 07:02 PM   #1
I have put up a FTP at 24.48.148.202, on port 21 for people to download.
The login is film. password is dvfilm
I was going to compare this quality with the Room 214 trailer on the other thread just for the heck of it. You can make up your own mind on which version to watch.
Quicktime version is smaller, not to bad looking either.
The HD version in 23.97 fps is better, but much larger in file size.
http://www.veoh.com/channels/filmmaker
My clips and films.
Bob Benkosky is offline   Reply With Quote
Old May 8th, 2003, 08:59 PM   #2
I wanted to say that if you use bulletproof ftp client, which is free, then you'd be able to download the file, then continue if u get disconnected.
My clips and films.
Old May 9th, 2003, 12:31 AM   #3
It's done!
New ftp server is up. Smaller 10 meg clip. Quicktime format compatible with all I believe.
24.52.42.73, on port 21
Login = film
pass = clip
If you can't get in, let me know. I do have a firewall up.
Just email me at alphaproject@adelphia.net to let me know.
By no means is this my best, lol. This was actually me fooling around bored at college. What is does show is nice movement and the must have wide angle lens. I would not film anything without one. Not only does it steady shots out, it looks awesome in widescreen. This is not the whole sketch, just a teaser of the beginning.
Check the IP, I had to update it. If you want to go there, it's up as of 10:14am Eastern Time (USA)
My clips and films.
