25mm F/1.4 - anyone use it yet? - Page 2 at DVinfo.net
Old May 9th, 2012, 08:43 AM   #16
Re: 25mm F/1.4 - anyone use it yet?
Yes, Jeff, in a controlled environment the lens is very nice. I guess I miss the 40mm of the 20mm lens, the extra width was nice. The 25mm is definitely a nice value at F/1.4 at around $500. The 12mm has me spoiled, it is just such a fine lens.
Old June 29th, 2012, 10:50 AM   #17
I also have the 12mm f/2.0. I agree, the 12mm is an amazing lens, definately a must in confined spaces, fast and wide.
I need to add the 25mm f/1.4 to my collection, it's looks great.
I'll probably still hold onto the 20mm f/1.7 which is also a nice lens.
I own a couple GH2 cameras which helps for event work.
Old June 29th, 2012, 10:51 PM   #18
As time has gone on I appreciate the 25mm F/1.4 more each time I use it.
Old July 16th, 2012, 03:50 AM   #19
Harper...
Which ND filter did you decide on for the 25mm 1.4? I need to get either a set or a variable ND filter for my outside clips.
Thanks in advance,
Jeff Hinson
Pana GH2, Canon XA10, Lenses 14-140 kit, 25mm f1.4 Pana,Rokinon 7.5mm f/3.5 ,50mm Pentax
http://www.dvinfo.net/forum/members/...on-albums.html
Jeff Hinson is offline   Reply With Quote
Old July 16th, 2012, 08:03 AM   #20
Guest
Posts: n/a
Why did I not see this thread last December? Christmas video with the AG-AF100 and the 25mm F1.4:
Old July 16th, 2012, 08:13 AM   #21
Jeff, I do not use a ND filter. I shoot so little outdoors, and am always rushed, I work without a ND filter. I also switch between three lenses when I work and the hassle of a ND filter is not worth it to me.
Ideally, it is much better to use a ND filter, of course, but I get by fine without one. I did test shooting with ND filters last year and the differences were minimal enough that I feel comfortable without.
Old July 16th, 2012, 09:00 PM   #22
I must have put my name on B&H's "notify me" list because Fri I got an email from them that they had a few 25mm f1.4's in stock.
I didn't hesitate.
According to tracking it started moving in the system at 7:46 tonight and should be here Wed 18th. Like you I plan to hang onto my 20mm f1.7, it's too useful a lens to let go.
Originally Posted by Jeff Hinson View Post
Harper...
Thanks in advance,
Jeff Hinson
Jeff, I'll "chime in" with my answer. I'm having good luck with the Polaroid ND Fader from B&H. I've got it in 37mm, 46mm, and 52mm sizes. So far I see no color shift and fitted with a rubber lens hood it gets so convenient to "dial" in outdoor exposure by slight adjustments turning the hood. Set shutter to 1/60th, aperture for desired effect, and "tune exposure" by turning the filter dial (or hood) until the meter indicates you "have it".
The 46mm size threads into the 46mm thread on the Lumix 20mm f1.7 (and the Lumix 14mm f2.5) but the filter thread on the front is 49mm. So I had a 49-52mm stepup ring and used that to hold a wide angle rubber 52mm hood (so the 20mm won't vignette). I haven't figured out what the front thread size on the 37mm and 52mm ND faders are, but I'm guessing 40.5mm and 55mm respectively.
I'll have to hit up a real camera store somewhere to see what fits. But I do like the variable ND filters, very convenient and some kind of ND is a must outdoors.
Old July 18th, 2012, 03:04 AM   #23
_________________________________________________________________________________
Thanks Bruce...
A few days ago I ordered NDX8s/0.9 for both my 25mm and 14-140 kit lenses....hadnt read your post yet. Of course they are not variable...but should give me some experience using NDs. Should arrive today I will see how they work....not that much invested in them.
Do you take your protective UV filter OFF...when using the NDs?
Old July 18th, 2012, 04:43 AM   #24
Ideally you should not stack filters. In the end what does it matter? Not much either way.
Old July 18th, 2012, 01:10 PM   #25
I've taken the "protective" UV filters off. I ran into no problem with them on Canon lenses (in fact they are required to complete weather sealing on the L series lenses when mounted on weather sealed bodies) but on the Lumix and Olympus Zuiko lenses I did begin to see some extra "flares" due to reflections.
So for protection I insure a lens cap is handy and cap them when not in use.
I also got some vignetting by leaving the UV filter on the 14mm Lumix when using the ND fader.
My 25mm f1.4 is "out for delivery", I'm on the "tail end" of my UPS guy's daily run so I get deliveries anytime between 4:30 PM and 6:30 PM. Doesn't matter much what time now, in a "freak" accident Sunday morning I took an impact to the face that required emergency eye surgery.
I have stitches to repair a tear in the Conjunctiva (lining over the eyeball), and stitches to repair a torn eyelid. Vision appears OK but I have to keep my left eyeball and eyelid "well greased" with an antibiotic ointment and don't know if I want to risk getting a GH2 all greasy trying out the new lens. I suppose I could just use the LCD...
Old July 18th, 2012, 03:55 PM   #26
I also use the Polarod ND filter on my 12mm and 25mm. (They have the same filter size!) I like it, but you have to be careful because as you close the filter - it creates an odd "Hourglass" shape if you close it too far. So keep a close eye on your viewfinders, especially in bright sunlight.
Angelo
Ironbird Studios - www.IronbirdStudios.com
New Jersey / New York City - Music / Audio / Video Production
Angelo Ucciferri is offline   Reply With Quote
Old July 18th, 2012, 05:28 PM   #27
@ BRUCE....
Seems like you had a real bad day....take care of that eye.
Hopefully getting the new lens will cheer you up a bit.
Hinson
Old July 19th, 2012, 10:05 PM   #28
Thanks Jeff, for the considerate comments.
Yes, getting the new lens did cheer me up a bit. What little I can tell playing with video in the living room with only one eye working, I think I am really going to enjoy using it. The "continuous autofocus" seems promising but I'll know more when I can get out and do some real testing.
It's like coming full circle. I remember getting my first real SLR, a Nikkormat that came with a 50mm f1.4 "normal" lens that most of us had to "make do" with until we could afford that 135mm f3.5 (actually I saved up a bit and got a Nikkor 105mm f2.5 instead then followed that (when I could afford it) with a Nikkor 28mm f3.5.
But I worked a lot with that 50mm f1.4 (did a lot of low light work on Tri X and Kodachrome 64) and that is what this lens feels like although it's sharper, crisper, and contrastier.
Zooms must have made a lot of us lazy and I'm looking forward to working with this lens, the 14mm f2.5 when I need wide angle, and the 45mm f1.8.
Bruce Foreman is offline   Reply
