Numbering of clips. at DVinfo.net
Old February 3rd, 2015, 03:47 AM   #1
Numbering of clips.
Hi I have two GH4. I Often run into problems with same naming/numbering of the clips and photos. I really would like if it was possible to set the start number on each of the cameraes. I often switch the SD cards after use and they adapt the folder name and numbers from each other - like "108_pana". Panasonic should fix this in the next firmware.
Bo Skelmose is offline   Reply
