HVX 200 + Mac +16:9 at DVinfo.net
Old November 9th, 2007, 06:34 PM   #1
HVX 200 + Mac +16:9
Hi all,
Debated where to put this thread, but figure there must be some Final Cut hanging here.. I have not worked much with this camera.. So need some advice.. In the end we will be shooting with this camera and bringing footage into Final Cut.. It is a very quick turnaround time (overnight) on an editied 2 or 3 minute piece...Camera will have Firestore drive to capture to.. The final has to be on a DVD and has to be 16:9..
So here is what I am not sure about should I shoot High Def and then drop it into Final Cut timeline with the sequence set to 16:9 DV ?? If so I assume it will need to render ?? Will it be a full screen 16:9 image (no black bars)??
Shoot it in high def, edit in high def and then compress it down to standard def 16:9 ???
Or shoot in DV 16:9 DV ?? Is this possible using this camera and the firestore and getting a 16:9 image out without black bars??
What will be the best soulution to get a 16:9 image out of the edit with
no black bars and the best quality image???
Thanks in advance to anyone who takes the time to answer!!
Mike Moncrief mikemoncrief@gmail.com
www.themikemoncrief.com
Mike Moncrief is offline   Reply With Quote
Old November 9th, 2007, 06:49 PM   #2
I shoot 720/24pNative and edit in a DVCProHD 720/24p preset.
I exported QT (not conversion), current settings, audio and video, self contained, no recompression.
I open Compressor, drop that video in the pane, and choose the DVD 16:9 preset consistent with the length of video in minutes, and Dolby2/AC3 audio.
Take the the m2v and D2 files, import to DVD, and make certain the 16:9 letterbox is chosen in DVDSP for a SD DVD, and author.
Why shoot or transcode to DV and compression 5:1 when you have great DVCProHD footage to start with?
David Saraceno is offline   Reply With Quote
Old November 9th, 2007, 06:52 PM   #3
Originally Posted by Mike Moncrief View Post
Hi all,
Yep. Export your 16:9 720HD into Compressor using the 16:9 Anamorphic setting in COmpressor. Creates a SD dvd that fills a widescreen TV. Happy Happy Joy Joy. Looks freaking awesome too.
Bob Woodhead is offline   Reply With Quote
Old November 9th, 2007, 07:12 PM   #4
Hi
Thanks for the reponses so far..I am not really looking for the 24P look, so i assume I can shoot in 720 in 60P ??
Thanks !!
Old November 9th, 2007, 08:30 PM   #5
Hello,
Another question for the HVX guys out there.. Pretty sure i know the answer, but need to verify.. When you shoot with the HVX 200 in HD.. It will only record HD to a P2 card or a Firestore drive and not to a tape.. Correct??
And if you record HD to a Firestore drive, can you also record to a tape at the same time?? And if so it will be DV???
Thanks all !!
Old November 10th, 2007, 10:52 AM   #6
You can record to FS-100, most NLEs, Scopebox and HD Monitor on a Mac, and OnLocation on PC any setting that streams out firewire. That means no pNative.
The cam has to be in either the tape mode or p2 mode. No simultaneous to both.
But you can dub.
Old November 10th, 2007, 11:16 AM   #7
OK, not sure I understand completely.. So you can recird DVCPRO HD 60P to Firestore ?? Correct ?? And to tape at the same time you can or cannot record?? If so what ??
Thanks..
Old November 10th, 2007, 02:38 PM   #8
The HVX2000 has to be either in the p2 mode OR the tape mode.
The FS-100 requires the p2 mode.
You cannot do both simultaneous. Either record to FS-100 and tape, or p2 and tape.
You can record to the FS-100 in any mode that streams out firewire, which is all support DVCProHD modes EXCEPT pNative modes.
Old November 10th, 2007, 05:07 PM   #9
Hi David,
Thanks for helping.. Maybe I am am missing it,but I am still not clear with this.. You say in the first sentence "that the HVX200 has to either in the P2 mode or Tape mode.."
then "the FS-100 requires the p2 mode"
OK, I can follow that....but then in the next sentence you conflict what you say in the first sentence with this:
"You cannot do both simultaneous. Either record to FS-100 and tape, or p2 and tape."
where you say record to" FS-100 and tape" which does not work with your first statement "either in the p2 mode or Tape mode"
Anyway maybe a simple Yes or No answer would work..
Can you record to tape at the same time as to the Firestore???
And if so what format will it be on tape , 16:9 DV ??
Thanks for the help..
Old November 11th, 2007, 12:26 PM   #10
No, it cannot do both simultaneously.
