HVX and Tape at DVinfo.net
Old November 10th, 2007, 07:13 AM   #1
HVX and Tape
Hi all,
I asked this question at the end of a post with a differnet topic, and figure it is buried so I am posting as a separate topic..(also I have to make some decisions on a rapidly approaching shoot. Have not worked with the HVX 200.. Looking for some verification of info on it.... from what I read and remember about the camera it will record HD (DVCPRO HD 60p) to the P2 card and to a Firestore drive, but not HD to a tape ?? Is this correct?? and if this is so, I will be using it with a Firestore drive.. Can I record to the Firestore and to tape at the same time?? And if this is possible, and I am recording the HD to the Firestore, what will I have on tape?? 16:9 DV ???
Any responses greatly appreciated...
Thnk You !!
Mike Moncrief mikemoncrief@gmail.com
www.themikemoncrief.com
Mike Moncrief is offline   Reply With Quote
Old November 10th, 2007, 08:54 AM   #2
Yes - HVX200 will only record SD signals to DV tape. If you want HD, you have to use either P2 or Firestore. What ever HD signals that is recorded to Firestore will be downgraded to SD to record on tape.
I don't know if the camera will allow recording of Firestore and tape simultaneously - somebody else can answer that for you.
TingSern Wong is offline   Reply With Quote
Old November 10th, 2007, 09:16 AM   #3
Thanks for the response.. Thats what I thought..
Anyone on the question of if you are recording to the Firestore in HD, can you record to tape at the same time?? And what do you get on tape DV 16:9 ??
Thanks!!
Old November 10th, 2007, 10:53 AM   #4
see my reply in other thread.
David Saraceno is offline   Reply
