Serious Magic DV Rack HD 2.0 work with HVX ? at DVinfo.net
Old December 11th, 2007, 04:33 AM   #1
Dose is Serious Magic DV Rack HD 2.0 work with HVX ? if its, Serious Magic DV Rack HD 2.0 sill to adobe on location, is that mean adobe on location work with HVX HD format ??? is that mean I can use the camcorder with out P2 card and I can get ever function like Variable frame rates in 720p mode:
12, 18, 20, 22, 24, 26, 30, 32, 36, 48, 60fps ?? any one have answer 4 this ?
Mouayed Zabtia is offline   Reply With Quote
Old December 11th, 2007, 10:17 AM   #2
In short, yes. You just cannot use the PN modes, as they do not output via firewire.
Dick Campbell is offline   Reply With Quote
Old December 11th, 2007, 12:19 PM   #3
Although OL will record DVCPRO HD, it does not record P2 MXF file format.
Also, if you are going to record HD via OnLocation, make sure you have a pretty beefed up machine or you'll get some dropped frames.
I look for a much more robust OnLocation in CS4.
-Brad
Brad Neal is offline   Reply
