HPX500 is 1080p or not? at DVinfo.net
Old February 6th, 2008, 12:02 AM   #1
This forum is a great resource! I have another question and my research on this question has brought me many confusing answers. Is the HPX500 1080p or not? Information on the HPX500 indicates it is 1080i/60 but has been quite flakey in indicating that is 1080p/30. Or perhaps I am reading way too much into this. I remember reading one source mentioning that the HPX500 imaging sensors actually capture 1080i/60 but the camera's recording system records that signal as 1080p/30 and thus "faking" 1080p/30.
Thanks for your help all.
William
William Reliford is offline   Reply With Quote
Old February 6th, 2008, 01:11 AM   #2
Bingo.
1080i60 = 1080p30.
It's the exact same amount of data.
The sensors are native progressive if that helps.
Old February 7th, 2008, 03:17 PM   #3
I don't think "faking 1080p" is quite the right way to put it. I'd say it embeds the 1080p30 stream in a 1080i60 stream. There is no goofiness with the final progressive pictures.
Jeff Heywood is offline   Reply With Quote
Old February 7th, 2008, 03:54 PM   #4
Unfortunately the terms "fake" and "true" are both grossly overused and poorly misrepresented in this particular industry. There are various ways to accomplish something. As Jeff points out, there's nothing wrong with the way this camera does progressive.
Old February 8th, 2008, 09:35 AM   #5
Panasonic Broadcast
The HPX500 does 1080P/30 or 24P/24PA
Hi,
The HPX500 captures and is able to record progressive images, be they recorded as 1080, 720 or 480. There is no trickery or fake progressive here, it is a true progressive picture. In the 1080 modes, the 24 frames will need to be extracted but these days, in most NLEs this is quite easy, like check a box on the import window.
If you look at the brochure for the HPX500, you will see that it does show and talk about the Progressive images. This is the source I would believe over all others.
Hope this helps,
Jan
Jan Crittenden Livingston
Panasonic Solutions Company, Product Manager for 3D and Handheld Cameras
Jan Crittenden Livingston is offline   Reply With Quote
Old February 9th, 2008, 12:25 AM   #6
I guess where it is confusing to me in the brochure is this:
1080/30p (over 60i)
What does "over 60i" mean?
Old February 9th, 2008, 04:36 AM   #7
I suspect it really means 1080psf/30 - "progressive, segmented frame". Which means a true progressive frame with the lines re-ordered, so instead of 1,2,3,4,5,6 etc a single frame becomes two fields 1,3,5 etc then 2,4,6 etc.
The data in the lines isn't changed or processed in any way (as with de-interlacing) so the true progressive nature of the pictures are maintained, it's just the order in which they are sent, and simple reordering losslessly reconstitutes the original. The reason is to make it compatible with a 1080i/30 signal from the point of view of a monitor etc.
David Heath is offline   Reply
