-   Panasonic P2HD / DVCPRO HD Camcorders (https://www.dvinfo.net/forum/panasonic-p2hd-dvcpro-hd-camcorders/)
-   -   New E-P2 cards (https://www.dvinfo.net/forum/panasonic-p2hd-dvcpro-hd-camcorders/235870-new-e-p2-cards.html)
Mark Donnell May 22nd, 2009 07:24 AM
New E-P2 cards
I was reading the Panasonic info on the new P2 cards announced at NAB, but had a few questions. The price has been lowered significantly, but I got the impression that the new cards will not last as long as the previous P2 cards. I believe that Panasonic said that with once-a-day recording, the new e-P2 cards will last about five years. Is card wear only dependent on recording, or would they also wear out in five years if the card were played back daily? They also seemed to imply that the new cards may not be quite a physically rugged as the earlier cards. Either way, they would be fine for my purposes, but I was curious about the differences.
Gary Nattrass May 22nd, 2009 07:44 AM
I have just ordered a 301 with four 32gb E cards, five years is the quoted time span but that will be fine for me and it ties in with the five year warranty.
They certainly look robust enough as they are still alluminium cased, I will haev them in about a week so can report more then.
Alden Miller May 22nd, 2009 10:59 AM
Gary
Where did you order them, I was under the impression they weren't out yet?
Alden
Gary Nattrass May 22nd, 2009 11:34 AM
Prestons in the UK have them:Panasonic AJ-P2E032XG P2
John Preston said all my kit was in stock so it will be with me by the end of next week.
Daniel Epstein May 22nd, 2009 11:41 AM
According to my sources the time limit on the E Cards is software controlled. Panasonic is using a different internal technology compared to the previous cards as well which helps with the price. It will be interesting to see if someone cracks the software code to extend the cycle limit on the cards or whether there is a true technological reason for the time limit.
Gary Nattrass May 22nd, 2009 12:14 PM
Use of once a day for five years is plenty enough for me, I have ordered the duel adaptor for the mackbook so the cards will be used in rotation and dumped to pro res daily.
Daniel Epstein May 22nd, 2009 01:58 PM
On my shoot yesterday we used 1 32 Gig card, 3 16gig cards and we used the 32 gig for 2 cycles and 2 of the 3 16 gigs for two cycles so it is relatively easy to see how having only a few cards could cycle faster than people might realize. Still not a big deal but worth noting
Andy Tejral May 22nd, 2009 03:10 PM
In another thread, maybe on DVX user, Barry Green said they worked like a disk drive. As memory locations stop working, they are mapped out of availability. So, you'd see a gradual decrease in space over time and eventually they'd announce themselves bad.
Yes, disk drives do the same thing--totally transparently. They generally have a reserve space so that is mapped in so you don't notice a decrease.
Yes, it is a software process but it is not planned obsolescence. I don't know this for a Panasonic-given fact but it makes sense.
Daniel Epstein May 22nd, 2009 05:27 PM
Andy,
I also heard the explanation you are referring to of how the new E cards worked when they first came out. I heard a different explanation more recently which made me doubt the initial explanation. I don't take this sources opinion lightly as they have had many years in the business. My experience with harddrives is they tend to fail to be reliable when the software has to map out new bad sectors. It remains to be seen if someone will try and extend the life of an E version card after the software has reached its designated cycle cut off. Most manufacturers would underestimate the durability of their products in this case so they don't run into too many early failures requiring reimbursement. Guarantee it for a number of cycles which 99.9 percent of the cards can achieve without problem. There is a good chance that 95 percent of the cards would last substantially longer. An example in this field was how long would video heads last on a machine. Some machines would last double the hours the manufacturer would recommend before needing replacement while others barely lasted what the manufacturer recommended. The person I was talking to thought the new E cards could function a lot longer than the software cycle was going to allow. Maybe he is wrong maybe not
Noah Kadner May 22nd, 2009 08:47 PM
Gotta admit the idea of software-determined obsolescence feels like usury to me. Why not just let gear wear out on it's own the old fashioned way?
-Noah
Tom Klein May 22nd, 2009 10:55 PM
-Noah
V
Latest Technology,
Days of Quality, long lasting products, are a fast fading memory, kinda nice idea though.
You just have to make it pay for it's self prior to it reaching it's "expiration" date.
Cheers
Tom K
TingSern Wong May 22nd, 2009 11:57 PM
Another viewpoint is this. If I am shooting on P2 - I want the data to be recorded with 100% certainty. Not 99.9999%. If Panny could only guarantee its E-P2 cards to be of a certain lifespan - I am not going to argue with that. If I am shooting a once-in-a-lifetime video - I don't want that E-P2 card to fail on me, just because we need to extend it's recording lifetime by a couple of months.
I also noticed an interesting question posted earlier on - does the wear and tear of the E-P2 cards only happen on the write cycle or both read and write? Meaning, if I record once, but read 100 times - does the 100 read cycles contribute to the shortened lifespan of the card?
Tom Klein May 23rd, 2009 12:48 AM
Hi TingSern Wong
sounds like you don't want it "Both Ways", a good question, I think that for 99% of P2 users the E-series cards will be fine, Every thing has a "Use BY" date, even the Highest quality, Highest priced R-series cards won't last forever they may fail any time also. I bet most R-series are redundant prior to being "worn-out", there is most likely a better/cheaper medium for aquisition on the drawing boards already.
Only wish the E-series were out prior to me purchasing three 32's and four 8's, all R-series, all very expensive.
E-series card buyers will turn a profit much faster than us early investors in P2.
Cheers
TingSern Wong May 23rd, 2009 01:03 AM
Hi Tom,
Yup - I deliberately delayed my purchase of higher capacity P2 cards for nearly 6 months - using the 60GB HDDs to offset the lack of capacity in the original P2 cards. Whew - I was lucky here.
Now, waiting for the 64GB E-P2 cards to be available - was told by end-August this year.
Of course, the question might be theoretical ... for me, I shoot on my HVX172, then read them into my workstation's RAID hard-disks and then work from there. So, for my case, one write, one read, then erase.
Other people who have the P2 enabled card readers from Panny or other sources - might not be the case. For them - one write, many reads, then erase. So - for them, this question of read cycles contributing to the degradation of memory cells might be relevant to them.
I do know - a newer technology of doing memory cells will put this degradation away forever. Panasonic could incorporate them into another series of P2 cards when this is available ....
Cheers,
TS
Gary Nattrass May 23rd, 2009 01:44 AM
Prestons have the 64gb cards now:AJ-P2E064XG
I suppose it makes sense to limit the card lifespan and as stated this happens on hard drives too.
What will be happening is that if the card sees a bad block it will automatically add it to the bad block map.
There are normally two bad block maps on a drive, the first one at manufacturer and is fixed. The second is dynamic and every time the disk is formatted it adds any new found bad blocks to the map and then knows not to try to write to them.
For big broadcasters like the BBC and SKY who use P2 a lot this E card mapping is good news as it allows them to manage their card useage and maintain integrity of rushes data.
TingSern Wong May 23rd, 2009 01:54 AM
64GB E-series available now? That's impossible. From their website (videokit.co.uk) ...
The 64GB E-Series P2 card will be available in August at a suggested list price of 720€.
Please read the website carefully :-).
Gary Nattrass May 23rd, 2009 02:29 AM
Sorry TingSern I stand corrected and I didnt read all the detail, I just looked on this page and saw that they are marked as available:H Preston
TingSern Wong May 23rd, 2009 02:32 AM
That's okay, Gary :-).
Tom Klein May 23rd, 2009 02:50 AM
Just found these releases re Fuji's E-series P2 card line up, they may be an alternative to pana's offerings, at least it's a choice some will explore.
Most likely they come from the same factory as Pana's ?
PR-USA.net - FUJIFILM Showcases New P2 Memory Cards at NAB 2009
Fujifilm Expands Professional Video Portfolio with P2 Format | Reuters
may dump my 8gigs R-series and get some E-series 32's, as I shoot SD DVCPro50 64 gig would be overkill for me.
TingSern Wong May 23rd, 2009 02:58 AM
They don't see Fuji's P2 cards in Singapore. We can only get Panny's P2 cards.
For me, the 64GB E-P2 cards are heaven-sent :-). I shoot HD-720p (and sometimes, in the mountains / wilderness areas, for up to a month at a time) - so the 64GB means I don't need to carry so many P2 cards with me - and along with it, the possibility of dropping the P2 cards down a ravine.
Tom Klein May 23rd, 2009 03:03 AM
I bought a 32gig Fuji late last year here in OZ, interesting you can't get them in singapore, yes the first time i swapped out a card in the field my heart was pumping too, as I did not want to drop it >
Funny thing, you can buy a good used car here in OZ for the cost of a R-series card.
TingSern Wong May 23rd, 2009 03:24 AM
Yup - some things you can get Down Under - you can't find here. I think the importer isn't interested in Singapore market - too small (and too specialised) for them.
I just got myself 3 tapes ... DLT VS1 tapes that is - only one shop in Singapore sells it ... and took me months to hunt for it. And incidentally, BluRay recordables are still very rare here - about SIN$25 for one. However, DVD+/-R disks are very common (about SIN$20 for 55).
Right - back to E-P2 cards - yes, that's exactly my point of not trying to swap P2 cards in the field ... so, for me, the larger the capacity of the card, the better ... HVX172 can take 2 P2 cards - that's make it for 128GB (2 x 64GB) ... plenty of recording time for me. Now, hoping Panny can actually deliver that card on time .......
Tom Klein May 23rd, 2009 03:34 AM
Yes, I suppose that's why the US market gets the first bite of the cherry on new products, size matters as they say. we smaller markets get the dregs or old technology is dumped off here. someone once said to me "we are a dumping ground", maybe they were right.
I Just set up a Pioneer Blu-Ray burner on my Macpro (in an external USB and esata case ) cost was $280 AUD for the burner , small extra $'s for the ext case. using Toast Titanum Ten software, BR blanks are still expensive but will drop over time as have DVD's.
TingSern Wong May 23rd, 2009 03:46 AM
BluRay writer prices are okay. About $250 - $300 locally. It is the blanks that are expensive .. not sure if they are viable long term - given that one OZ researcher just did a 2,000 GB optical media (you did read that correctly - 2,000 GB) - and told Samsung to make the drives :-). Now, if we know the Koreans - they will be jumping up and down in bed ... given the opportunity to beat the rest of the world. We see in due course .......
Tom Klein May 23rd, 2009 03:53 AM
I have had the odd request for Blu-Ray so I decide to get a burner and have a play..still, much cheaper than my first DVD burner from memory I paid $1100 AUD, and with-in 12 months they were under $200.
but we all learnt so much. now DVD is great 99% of the time.
2000gig, whoa,that may shake the market, But I think DVD is here for some time yet, it's cheap and every man and his dog can burn / play them.
TingSern Wong May 23rd, 2009 03:57 AM
Understand your point. Locally, nobody is interested in BluRay at all. Not even large companies. DVDs are good enough for them. Most of them only has SD players - no HD. Hence, no use for BluRay for me right now.
Noah Kadner May 23rd, 2009 09:09 AM
Originally Posted by Tom Klein (Post 1147132)
Hi TingSern Wong
Cheers
That's fine but I've personally never, ever seen a Flash card, P2 or SDHC card stop working. I thought the whole point of this technology was no moving parts, lasts forever. So the idea of artificially limiting a card's life span to a specific number of cycles is about profit, not about 'protecting' users from some sort of failure.
If a memory fails on it's own, that's fine. It happens once and you'll know about it immediately and get another when. But why should it fail just because the software tells it to? Imagine if you bought a computer that said on the box, will stop working in exactly two years to protect you from experiencing the potential of a natural failure. Wouldn't you feel kinda gypped?
-Noah
Daniel Weber May 23rd, 2009 02:43 PM
The company I worked for paid $5000 for the first Pioneer burner on the market (it burned DVD (A) discs.) It think it would have been around 1998 or 1999.
Daniel Weber
Giroud Francois May 23rd, 2009 03:12 PM
"If a memory fails on it's own, that's fine"
Yep, any piece of electronic must fail one day or another.
So if the manufacturer does limit the lifetime of such device to a predefined time or cycle, it is to make sure it does not happen randomly (and some law says it always be at the worst moment).
So they can print on the package, that the memory is ok for 50.000 write cycle and you know that there is very little chances that will happen before.
on the other hand, you can guess that some cards "could" operate properly on 70.000 write cycle or even more. But chances there would be a failure will go up significantly too.
I am not sure people would accept that.
Tom Klein May 24th, 2009 02:46 AM
Hello Daniel,
From Memory my First DVD Burner was the Pioneer A01, it made many many coasters out of $35 AUD blank DVD's , This early foray into DVD , yes back in the last millenium, was an expensive exercise indeed.
was yours a Video disc burner , $5000 sounds over the top..
Cheers
Tom Klein May 24th, 2009 03:19 AM
-Noah
Hi Noah,
I have many industry colleagues who repair current electronic equipment, they tell me (and I believe them) that most goods built these days are built to last not much more than the warranty period.
I have personally owned many devices that last not much longer than the warranty period, that is where I base my opinions on longevity of current electronic devices.
I believe that as you pointed out above (said on the box, will stop working in exactly two years) that is the case , it's just called another name,"Warranty"
seriously, does anyone believe a R-series P2 card will "Last Forever" , I don't.
EG, about 3months ago I replaced 7 DVD burners in my Burn Tower (with brand new units of course), now two burners in the stack are failing to burn/verify and will have to be replaced, they may have only burnt 30 or so disc's each. they all have 12 months warraty,go figure ?, Nothing lasts forever.
Cheers
Barry Green May 25th, 2009 11:07 AM
Noah, look into MLC memory vs. SLC memory. Two different technologies, and SLC memory will last 10x as long as MLC.
MLC is cheaper. It's denser. You can store multiple bits per cell (hence the "M", meaning Multi).
SLC memory lasts much longer, and you can read lots of articles on MLC vs. SLC when you look into SSD drives.
SLC memory should last for 100,000 rewrite cycles, MLC memory lasts for about 10,000.
As to the question of whether reading the memory will cause it to wear out, I don't think so but don't know for sure. It's my understanding that it's "rewrite" cycles that are limiting the lifespan, MLC only supports up to 10,000 rewrites. So possibly you could read it a million billion times but write only 10,000 times?
Mark Donnell May 25th, 2009 05:51 PM
Barry - it will be important to me, and I'm sure to others, that if the card expiration is indeed software-controlled, is it based only on the number of record cycles, or is playback also counted. If playback is counted, I will ensure that I use older series cards for frequent playback and the E-series for record and dump once. If Panasonic could clear this up it would be helpful.
TingSern Wong May 25th, 2009 07:53 PM
Originally Posted by Barry Green (Post 1148019)
MLC memory should last for 100,000 rewrite cycles, SLC memory lasts for about 10,000.
Barry,
I believe you got that mixed up :-). SLC memory will last 100,000 rewrite cycles, whereas MLC will only go 10,000 times.
Cheers,
TS
Barry Green May 25th, 2009 09:48 PM
Edited and fixed.
Tom Klein May 25th, 2009 10:20 PM
100,000 rewrite cycles?
the connectors will be well worn out prior to that being achieved, in the real world of field shooting, grit etc will get amongst the sockets and pins, and speed up the wear factor.
May I re-say with respect, "Nothing lasts forever".
Cheers
Barry Green May 26th, 2009 11:22 AM
Cheers
Connectors have been tested to 30,000 insert/remove cycles. But with the bigger cards, it may come to the point where people never even remove their cards. If you had two 64gb cards, which could record 12 hours of 720/24pN footage in AVC-I 50, it's conceivable that you could leave those two cards in-camera all day long, and transfer at night. You'd never need to swap, as you couldn't physically shoot more (in a normal 10-hour day) than you could fit on the cards!
In any case, yes, 100,000 rewrite cycles. And yes, I've asked and been told that read cycles do not contribute to them wearing down, you can read as many times as you want, it's writing that wears out the memory.
Tom Klein May 26th, 2009 05:40 PM
Hi Barry,
If the connectors have been tested to 30.000 insertion / remove cycles, does that mean that they failed at that point or did they consider it was their life cycle limit ?. Saying that they are good for 100.000 writes but only testing insert / remove to one third of that, leaves me thinking Hmmmmm.
Bigger capacity P2 cards sure will reduce the need for removal for reading on bigger shoots, but for many shoots as news/EFP/etc, shooting 10-20mins is about the norm.
The two slot P2 camera's will have cards removed /inserted many more times than the four and five slot P2 cameras.
The newer E-series will be welcomed by many users, I doubt whether the R-series will survive the long haul, probably fade into techno oblivion.
cheers
Barry Green May 27th, 2009 02:43 PM
It is my understanding that they had a machine physically plug in and remove the card 30,000 times with no failures, and they said "okay, that's good enough for us." There was no failure, but 30,000 times of plugging it in and out (which equates to inserting and pulling the card 3x a day every day for 10 years) was enough to get the point across.
Why? Many folks don't even pull their cards out at all, using the camera as the offload station. But if 30,000 times aren't enough for you, well... :)
Andy Shipsides May 27th, 2009 03:33 PM
Panasonic has released some details about the new firmware needed to make the E-Series cards be all they can be. Check out the chart on their site - https://eww.pavc.panasonic.co.jp/pro...te.htm#p2_card
And I wrote up a little article on my blog as well - E-Series P2 Card Firmware Updates | CineTechnica
