HVX-200 info, might be new - Page 3 at DVinfo.net
Old April 16th, 2005, 05:11 AM   #31
oops :)
I also forgot Bluefish4:4:4 too. Their cards also directly support input and output of DPX files.
Jason Rodriguez is offline   Reply With Quote
Old April 16th, 2005, 11:00 AM   #32
Jason, thanks for the response.
"In the case of the Kinetta, Drake, Obin's camera, etc., though, the files are already digitized on the hard-drive of these cameras, so you don't have to worry about that. The only issue is to have them in a Quicktime or AVI file format that can support 10-bit or greater RGB 4:4:4."
That is the part where I really get lost.
If I were to use one of those cameras, I wind up with a hard drive with 10bit log files on it. What do I use to then transcode those log files into an AVI or Quicktime format which I can edit in FCP or Avid?
Once they are transcoded, is there any need to go back to those log files for an 'online,' or are my Quicktimes treated as the 'masters' from that point on (for color correction, etc)?
I'm just trying to understand the workflow, before I find myself in a position where I may have to use it.
Thanks.
Luis Caffesse
Pitch Productions
Austin, Texas
Luis Caffesse is offline   Reply With Quote
Old April 18th, 2005, 07:18 AM   #33
RED Code Chef
In the case of Drake and Obin's camera there should be software with the
camera that facilities transforming the original files to other file formats etc.
From what I understand the Drake camera is still 8 bit though... Just a higher
resolution / uncompressed (not sure if it is "true" uncompressed with Drake).
Rob Lohman, visuar@iname.com
Old April 18th, 2005, 07:25 AM   #34
Thanks for the reply Rob.
I also found out in the meantime, according to a friend of mine, that AE can read DPX files...which means in theory I guess you could use AE to render out Quicktimes (although that would be pretty time intensive).
Luis Caffesse
Pitch Productions
Austin, Texas
Old April 20th, 2005, 11:12 AM   #35
Originally Posted by Jason Rodriguez
For higher-end editing beyond Final Cut Pro, you options are AVID/DS, Smoke, Quantel, Assimilate, Nucoda, etc.
I'm not really familiar with all this, but I know that Cinegy Extreme can work wit 2K, 4K and Cineon in 32bit files as well. It also fully supports Bluefish4:4:4.
Michael Maier is offline   Reply
