CAC Profiles for HPX370 Lenses at DVinfo.net
Old October 9th, 2011, 12:13 PM   #1
Does anyone know if the Fujinon 13x3.5BRMU is CAC compatible, and if so, where that profile could be downloaded? The 370 manual directs you to the master pro-av website, but I can't find any CAC info. I'm thinking that the difficulty I'm having probably means it isn't, but I'm still holding out hope!
One of the things I liked about the newer JVCs was that you could dial CAC compensation manually, but the 370 seems to only use existing profiles. Please correct me if that's not correct.
Dave Coulter is offline   Reply With Quote
Old October 9th, 2011, 01:57 PM   #2
Re: CAC Profiles for HPX370 Lenses
I don't think there is a CAC file for this lens but you may get some more info here: HPX370 Lens Options [Archive]
Old October 9th, 2011, 02:49 PM   #3
Thanks Gary,
That is helpful. I didn't see that thread when I was searching. I finally found the master list:
https://eww.pass.panasonic.co.jp/pro...cac_note_e.htm
and it confirms that the 13x3.5 isn't there. In fact none of the fuji lenses are approved for CAC except the one that ships with it. I didn't think the shading adjustment was for CA, but I'll play with it and see if it's improved. CA was never bad with that lens anyway!
