firewire 400 or 800 for direct to laptop at DVinfo.net
Old March 28th, 2006, 06:40 PM   #1
trying to work out if there's any point in using 9-pin firewire (with compatible external drive) for recording direct to laptop.
since the camera only has 4-pin output (requiring adaptor on the cable anyway) would an 800 speed cable be redundant?
any thoughts?
Tim Schultz is offline   Reply With Quote
Old March 28th, 2006, 07:05 PM   #2
The HVX is a IEE1394a/firewire400 device, so it wont make a difference for the camera cable. But if you also use an external firewire disk to capture to connecting that to the 800 bus will be the best option.
Anders Holck Petersen is offline   Reply With Quote
Old March 28th, 2006, 10:46 PM   #3
Hawaiian Shirt Mogul
if you have a PC microsoft pretty much killed 1394b with XP service pack 2.
conisider it lucky if you can get 1394a speeds using a 1394b card bus and 1394b external drives.
completely different story if you have XP service pack 1 = you'll get the max thru put of the drive you hook up over 1394b to 1394b .. around 60-65MBs on 400 gig drives
Don Donatello is offline   Reply With Quote
Old March 29th, 2006, 12:22 PM   #4
Win2k and 1394b
If I'm still using Win2k Pro sp4, will i see the same problems with going to 1394b?
Jim Hawley is offline   Reply
